Amazon
X002x9rp1J / B016101. The camera also has UC-545 Rev C in silkscreen print
Raspberry Pi Zero W
https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov7251-0-3mp-global-shutter-raspberrypi-camera/
Not that I know of
After following the instructions from the link above, /dev/video0 is not listed. The red LED blinks on a Pi reboot, which helps confirm the cable is installed correctly.
Reformatted and installed Raspbian from a clean image sudo apt update sudo apt upgrade sudo rpi-update Ensured the cable is the correct orientation on both the pi and camera board Stackoverflow / Google searches to see if others had this problem
I would like to get the camera working, preferably with OpenCV at the higher framerates (> 150fps)offered at 320x240 resolutions.
/boot/config.txt file:
http://rpf.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
#dtoverlay=vc4-fkms-v3d
dtoverlay=dwc2
dtparam=i2c_vc=on
dtoverlay=ov7251
start_x=1
gpu_mem=128
output of >> cat /var/log/syslog | grep ov7251:
Jul 28 22:21:06 raspberrypi kernel: [ 26.176455] ov7251 10-0060: cannot get enable gpio
Jul 28 22:21:06 raspberrypi kernel: [ 26.208175] ov7251: probe of 10-0060 failed with error -2
Jul 28 22:21:12 raspberrypi kernel: [ 33.130765] ov7251_dvdd: disabling
Jul 28 22:21:12 raspberrypi kernel: [ 33.130796] ov7251_dovdd: disabling
Jul 28 22:21:12 raspberrypi kernel: [ 33.130814] ov7251_avdd: disabling
Jul 28 22:46:17 raspberrypi kernel: [ 26.022667] ov7251 10-0060: cannot get enable gpio
Jul 28 22:46:17 raspberrypi kernel: [ 26.049663] ov7251: probe of 10-0060 failed with error -2
Jul 28 22:46:24 raspberrypi kernel: [ 33.135923] ov7251_dvdd: disabling
Jul 28 22:46:24 raspberrypi kernel: [ 33.135955] ov7251_dovdd: disabling
Jul 28 22:46:24 raspberrypi kernel: [ 33.135974] ov7251_avdd: disabling
That error traces back to the kernel module code: https://github.com/torvalds/linux/blob/master/drivers/media/i2c/ov7251.c
on lines 1356. I’m wondering if dwc2 is causing a GPIO pin conflict.
Nope, put it on Wifi and removed dwc2, still no luck
Ok, my next step was to run the examples in MIPI_Camera. The output from ./capture_raw is:
pi@raspberrypi:~/MIPI_Camera/RPI $ ./capture_raw
Open camera…
sh: 1: gpio: not found
sh: 1: i2cdetect: not found
Hardware platform: 9000c1
Found sensor ov7251 at address 60
Setting the resolution…
Last update for the evening, I was able to get a bit further by reinstalling wiringpi and i2c-tools. This helped resolve the GPIO and i2cdetect issues.
Unfortunately, /dev/video0 is still missing. ./capture_raw also does not return anything but does show the following:
Open camera…
Ok, I think the issue is solved, though the camera is not showing up under /dev/video0 the arducam C library works to get 200fps @ 320x240 which is perfect!
Probably the main issue was I was running rpi-update which was causing firmware issues. I also started using the 2.52 wiringpi library mentioned in the Github page, though the notes say that it is only for the Pi 4.
Great to hear that. Thanks for your sharing.
