I am using 2 Arducam OV7251 boards (UC-545 Rev. C) with a StereoPi IO board (RPi 3 compute module). Everything is working great, but I would like to see if I can synchronize the two cameras better. There are connections for FSIN and Strobe on the boards and I am wondering if it’s possible to connect the Strobe of cam1 to the FSIN of cam2 and then configure cam2 shutter to go on FSIN (external trigger)? Can you let me know if that sounds like a feasible approach and if there is a software setting for the external trigger could you help me find where to set it (I am using the latest Arducam MIPI software from Github as of 2020-11-17).
Thank you for your reply, but I don’t quite understand. “External mode configuration” is the correct thing to use isn’t it? Means to trigger the shutter on FSIN?
Hello, external mode has two type, Master mode and slave mode. all of our ov7251 is slave mode, which means, the sensor’s strobe signal is not output, you should use external trigger signal to trig the sensor instead of connecting the signal to another sensor’s strobe pin, If you want to conenct one camera’s strobe to another camera’s FSIN pin. For the first camera, you should configure it to master mode and ensure the strobe signal is normal. For the other camera, you should configure it to slave external mode. Now we just have external slave mode and we don’t have master configuration.
