We have ov5647 from Arducam (5MP OV5647 - Arducam Wiki), we need to integrate it on Orin nano DevKit with OrinNX16G ( JetPack 6.2 / L4T R36.4.3 ). May I know where can I get the driver for ov5647. We tried IMX219 on Orin nano DevKit with OrinNX16G ( JetPack 6.2 / L4T R36.4.3 ), and IMX219 works well. I think I can use same FPC for both IMX219 and ov5647?
Hi @AmberTsai
Thanks for reaching out to us…
For the IMX219/IMX477 camera, there are native drivers on the Jetson, so you can use them seamlessly on your Jetson Orin device.
Unfortunately, the OV5647 camera module won’t be able to work on the Jetson platform due to the absence of the native OV5647 camera driver.
Hi Dion,
Yes, I know that there is no native drivers on the Jetson Orin Nano for OV5647, and there is native driver on the Jetson Orin Nano for OV5693. I would like to know if you can provide driver that works on Jetson Orin Nano DevKit for OV5647?
Hi @AmberTsai
I know it’s not the answer you were looking for. However, we currently don’t have the native OV5647 camera driver.
You can choose another camera as an alternative on the Jetson platform.
Hi Dion,
I have a question for you.
I fount that there is a CamArray HAT “SKU : B0396”, it will combine 4 x IMX219 into one frame.
My question is, may I use two CamArray HAT “SKU : B0396” for getting two frame from 2 x 4 x IMX219 on Orin NX carrier board?
Hi @AmberTsai
It will work for you. However, please note that these two frames are not synchronous.
Hi Dion,
If I need to connect one CamArray HAT “SKU : B0396” on J20 of Orin nano super DevKit, and another one CamArray HAT “SKU : B0396” on J21 of Orin nano super DevKit.
I think I should to provide power to both CamArray HAT “SKU : B0396” by using USB type-c, instead of the GPIO Header of Orin nano super DevKit?
Not sure which carrier board you’re using. If these carrier boards don’t have GPIO pins, you need to power the B0396 HAT with a single Type-C.
Hi Dion,
According to “Quick start - Arducam Wiki”, user need to plug CamArray HAT into Jetson Nano GPIO Header.
But, if I have to use two CamArray HAT “SKU : B0396” on Jetson Orin nono DevKit, there is no way to connect two CamArray HAT into Jetson Nano GPIO Header.
So, I’m thinking that I can power two CamArray HAT “SKU : B0396” with type-c instead of Jetson Nano GPIO Header.
Nail it. You’re completely correct.
