Ov5647 fisheye camera not found
    Amazon
    5MP OV5647 wide angle fish eye
    Raspberry pi 4
  4. Instructions you have followed. (link/manual/etc.) manual. link from the instructions. Also traded my other rasp camera module 3 which worked. Even traded cables each time. the module 3 works, but not the arducam O5647
  5. Problems you were having? Camera not found
    $ libcamera-hello
[0:00:33.542258571] [2100] INFO Camera camera_manager.cpp:327 libcamera v0.4.0+53-29156679
[0:00:33.582843404] [2106] WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:00:33.585158978] [2106] INFO RPI vc4.cpp:447 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media0 and ISP device /dev/media2
[0:00:33.585273182] [2106] INFO RPI pipeline_base.cpp:1121 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
Preview window unavailable
Mode selection for 1296:972:12:P
SGBRG10_CSI2P,640x480/0 - Score: 3296
SGBRG10_CSI2P,1296x972/0 - Score: 1000
SGBRG10_CSI2P,1920x1080/0 - Score: 1349.67
SGBRG10_CSI2P,2592x1944/0 - Score: 1567
Stream configuration adjusted
[0:00:33.588181849] [2100] INFO Camera camera.cpp:1202 configuring streams: (0) 1296x972-YUV420 (1) 1296x972-SGBRG10_CSI2P
[0:00:33.588646663] [2106] INFO RPI vc4.cpp:622 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
[0:00:34.688078570] [2106] WARN V4L2 v4l2_videodevice.cpp:2150 /dev/video0[13:cap]: Dequeue timer of 1000000.00us has expired!
[0:00:34.688161089] [2106] ERROR RPI pipeline_base.cpp:1367 Camera frontend has timed out!
[0:00:34.688174959] [2106] ERROR RPI pipeline_base.cpp:1368 Please check that your camera sensor connector is attached securely.
[0:00:34.688189311] [2106] ERROR RPI pipeline_base.cpp:1369 Alternatively, try another cable and/or sensor.
    dmesg | grep ov5647
[ 0.049041] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/ov5647@36
[ 0.049117] /soc/i2c0mux/i2c@1/ov5647@36: Fixed dependency cycle(s) with /soc/csi@7e801000
[ 0.050148] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/ov5647@36
[ 0.064687] /soc/i2c0mux/i2c@1/ov5647@36: Fixed dependency cycle(s) with /soc/csi@7e801000
[ 3.920530] /soc/csi@7e801000: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/ov5647@36
[ 3.920598] /soc/i2c0mux/i2c@1/ov5647@36: Fixed dependency cycle(s) with /soc/csi@7e801000
    modified firmware config
    different cable
    comparing with a different camera
    updating raspi
config:
sudo cat /boot/firmware/config.txt
http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
#dtoverlay=imx708
dtoverlay=ov5647
camera_auto_detect=0
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=on
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
dtparam=eth_led0=4
dtparam=eth_led1=4
  1. What help do you need?
    Help me to get this working or decide if I need to get a replacement.
Please post the FFC you are using here.
best regards,
-Dion
Thank you!
I’m not sure if it’s 30cm or not. Can u confirm it for me?
Additionally, do you have another FFC in your hand? If so, could you give it a shot?
Thank you, yes it is a 30cm.
I used that one and then a second 30cm, both which work with the raspberry pi camera module 3. I also tried a 20cm and a 15cm. All give the same results.
Could you send dm me the order number? We will initiate the replacement process.
Im not sure how to dm in this forum?
Just click on my profile and then click Message.
Oh, sorry. That button doesn’t appear for me. I sent it to the moderators group. Im not sure if that works.
The time difference is a bit inconvenient.
Perhaps the easiest way to reach us would be by email at [email protected]. Please include a link to this forum thread and your order number.
Sorry for the time waste :((
