ArduCAM-Mini-5MP-Plus OV5642 Camera Module -
ESP-12F -
When working with ESP-12F as websocket server for streaming, I measured the time between the start of the capture and the value of CAP_DONE_MASK = 1 is almost 1s, so I measured with a variable how many times in 1s I check the flag CAP_DONE_MASK (while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK)) and the result is almost every 10ms, so the frame rate is really low, can you explain that? Is my measure coherent? I understand that the time to send the capture to 8MB FIFO is too high. -
to understand on what depends the time from capture to 8MB FIFO
