botland
ov2311
raspberry 4B 8GB 32 bit
instruction on github
Yes and it is currently working.
I can detect the ov2311 via i2cdetect -y 0 and make a picture using capture but cannot make a picture using Python this leads to NULLPOINTER access.
I researched this bug and made a simple example here https://github.com/hstarmans/Arducampython/tree/master/test .
The CPP file is identical to the C file. The C file works. The CPP file only works if I use
CXXFLAGS?= -I. -g -std=gnu++11
If I use
CXXFLAGS?= -I. -g -std=gnu++11 ${OPENCV_LIB}
I get a segmentation fault and can’t capture the picture.
I am quite sure this is the same problem that is causing problems in Python.
made a simple example in cpp
create a working python example / fix library
