Amazon -
SKU B0322, OV2311 UVC USB Arducam camera -
Windows 10, USB UVC -
Quick Start - Arducam UVC Cameras on Windows - Arducam -
I’m having trouble getting the camera to be very effective in low light because of this pattern, a gradient that looks like the opposite of lens shading. With the camera shielded from all light, it shows this pattern basically identically with any exposure length, and it’s not affected by running lower fps or attaching a heatsink to the back of the sensor. It does however change slightly as light is let in and the scene brightness changes, so I’ve been unable to calibrate it away. Increasing gain increases the brightness of the whole image including the gradient. I’m trying to use this sensor on a 200mm lens for star detection and tracking, and the gradient and banding are making the software struggle to differentiate that from the gradients of the stars themselves.
(not on linux) -
I’ve tried 4 different UVC camera control apps and they all show the same behavior: Amcap, Sharpcap, PHD2, and the Windows camera app. Different apps have different amounts of success controlling the camera, but the gradient appears the same on all of them. -
What help do you need help with?
How can I get rid of this gradient? What is it?
Thanks,
Hans
