UCTRONICS
Arducam 2MP OV2311 Global Shutter NoIR Mono Camera Modules for Raspberry Pi
Raspberry Pi 4B
https://www.arducam.com/docs/pi/ov2311/tutorial/#18-3run-demo-through-the-arducamstill-command
Worked for a few single frame capture tests then suddenly stopped working
I just started playing with an Arducam OV2311 camera by running through the demo listed in the link above. I had some initial success pulling a few images using the arducamstill routine and also the python script ‘capture.py’. All of a sudden I am unable to capture images and there has not been any change to the hardware configuration.
Here’s the current output from arducamstill:
pi@spectrometer:~/MIPI_Camera/RPI $ ./arducamstill -t 5000 -m 0 -o testimage.jpg
Open camera…
Hardware platform: b03112
Found sensor ov2311 at address 60
mode: 0, width: 1600, height: 1300, pixelformat: GREY, desc: (null)
mode: 1, width: 1600, height: 1300, pixelformat: BA81, desc: (null)
mode: 2, width: 1600, height: 1080, pixelformat: GREY, desc: (null)
mode: 3, width: 1600, height: 1080, pixelformat: BA81, desc: (null)
mode: 4, width: 1920, height: 1080, pixelformat: GREY, desc: (null)
mode: 5, width: 1920, height: 1080, pixelformat: BA81, desc: (null)
mode: 6, width: 1600, height: 1300, pixelformat: Y10P, desc: 1600x1300 RAW 10 mode
mode: 7, width: 1600, height: 1300, pixelformat: GREY, desc: Used for ov2311 2lane raw8 1600x1300 external trigger mode
mode: 8, width: 1600, height: 1080, pixelformat: GREY, desc: Used for ov2311 2lane raw8 1600x1080 external trigger mode
mode: 9, width: 1920, height: 1080, pixelformat: GREY, desc: Used for ov2311 2lane raw8 1920x1080 external trigger mode
mode: 10, width: 1600, height: 1300, pixelformat: Y10P, desc: Used for ov2311 2lane raw10 1600x1300 external trigger mode
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 0
index: 1, CID: 0x00980915, desc: V4L2_CID_VFLIP, min: 0, max: 1, default: 0, current: 0
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1466, current: 7936
index: 3, CID: 0x00980913, desc: V4L2_CID_GAIN, min: 0, max: 255, default: 0, current: 0
index: 4, CID: 0x00981901, desc: V4L2_CID_ARDUCAM_EXT_TRI, min: 0, max: 1, default: 0, current: 0
Failed to set focus, the camera may not support this control.
Start preview…
Current mode: 0, width: 1600, height: 1300, pixelformat: GREY, desc: (null)
Mono camera does not support automatic white balance.
mmal: Enable JPEG encoder.
Here’s the current output from capture.py:
pi@spectrometer:~/MIPI_Camera/RPI/python $ python capture.py
Open camera…
Setting the resolution…
Current resolution is (1920, 1080)
Reset the focus…
reset_control: Unexpected result.
The camera may not support this control.
Enable Auto Exposure…
Enable Auto White Balance…
software_auto_white_balance: Unexpected result.
NULL pointer access
I tried reinstalling/rebuilding the SDK but saw no changes to the issue stated above. Found a post from another user about the ‘NULL pointer access’ and it looks like it may be from damaged hardware
The camera + RPI are mounted and there was no physical change between successful image captures and when it stopped working. Likewise, there were no changes to the RPI environment, so it’s hard to assign this issue to software. Are there any tests I can do to confirm the hardware is fully functional?
