[ 99.760170] CAM_ERR: CAM-SENSOR: cam_sensor_match_id: 655 chip id 0 does not match 2311
[ 99.760175] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 742 Not a hot plug sensor, match sensor id failed
I need the OV2311 datasheet where all camera registers with values written on that.
First, please post a picture of the hardware connection.
Second, the OV2311 datasheet is controlled by the chip manufacturer, and we do not have the right to share it, even though we do not have it (because you just told me the type of camera, and there are many cameras with the same chip…)
We have to use 0x18 slave id then we got the below log;
[ 97.139094] CAM_ERR: CAM-SENSOR: cam_sensor_match_id: 655 chip id ffff does not match 2311 [ 97.139097] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 742 Not a hot plug sensor, match sensor id failed
can you please guide me to solve the issue of the Slave id and sensor id?
We have not tested the HAT on the carrier board you use. Could you connect the HAT board directly to the Raspberry Pi 4 to check if the HAT kit is able to work properly?
