Arducam Forum Support Request (Final Version)
- DeviceMart (South Korea) - Direct Link
- B0429 (Arducam AR0234 Color Global Shutter)
- Hardware: NVIDIA Jetson Orin Nano Super Developer Kit
- JetPack Version: 6.2.1 (L4T 36.4.7)
- Boot Environment: Booting from SD card and pivoting to NVMe SSD.
- I tried using the official
install_full.shscript multiple times, but it failed consistently with errors. - Due to the script failure, I had to perform a manual installation of the Jetvariety driver, configuring the kernel modules and device tree overlays manually for L4T 36.4.7.
5. Problems you were having?
- The camera works perfectly only once immediately after a cold boot.
- Lane Switching Issue: When monitoring the logs, the MIPI configuration initially starts at 2-lane (working fine). However, during execution, it suddenly switches to 4-lane.
- Once it switches to 4-lane, any subsequent attempts to run the camera result in a black screen, 1~2 FPS, and persistent timeout errors. It stays stuck in the 4-lane state until a full reboot.
`Bash# Initially starts at 2-lane (Working)
[ 155.859376] arducam-csi2 9-000c: show_csi_params: csi port lanes: 2
Suddenly switches to 4-lane during execution (Failed)
[ 156.959958] arducam-csi2 9-000c: set_channel_lanes: csi port lanes: 4
Subsequent runs result in constant timeouts
[ 219.615717] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 219.615742] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel`
- Service Reset: Restarted
nvargus-daemon(No effect). - Hardware: Re-seated the MIPI CSI ribbon cable multiple times.
8. What help do you need?
- Is there a way to force the arducam_csi2 driver to stay in 2-lane mode and prevent it from automatically switching to 4-lane?
- Why does the lane count switch suddenly and remain stuck at 4-lane after the session ends?
- How can I fully reset the MIPI CSI bridge state without a full system reboot on the Orin Nano Super?
