Hi @chris42
HUhhhh, Sorry for that. I’ve posted the correct link:
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/
@GlobalHawk @mcbrady @sblaue @andref @chris42 @martin
Hi there,
You guys can check the compatibility status in the following link.
https://docs.arducam.com/Nvidia-Jetson-Camera/Introduction-to-Arducam-Jetson-Cameras/#official-nvidia-jetson-agx-orin-development-kit
I’ll update the compatibility list as soon as we’ve verified and uploaded the camera driver.
Hi @Dion,
The 39.2.1 IMX477 driver works on my B0251 — thanks. Two issues.
Setup: B0251 on Jetson Orin Nano Super Dev Kit (p3768-0000+p3767-0005), L4T 39.2.1 (REVISION 2.1, GCID 46758480), arducam-nvidia-l4t-kernel-t234-nx-6.8.12-tegra-39.2.1-20260824170248_arm64_imx477.deb
- Single-camera overlays fail; dual works
- imx477-dual, one camera on CAM0: works
- imx477-dual, one camera on CAM1: works
- imx477-dual, two cameras on CAM0+CAM1: works. both stream simultaneously
- imx477-A on CAM0: INVALID_SETTINGS
- imx477-C on CAM1: INVALID_SETTINGS
Please find the detail log at the end
In both failing cases the sensor is detected (imx477 9-001a → /dev/video0) and modes enumerate, then Argus fails right after “Starting repeat capture requests” with INVALID_SETTINGS / Argus Correctable Error Status, with or without an explicit sensor-mode.
Likely clue — the overlays expose different mode tables:
dual: 4032x3040@21, 3840x2160@30, 1920x1080@60
A and C: 3840x2160@30, 1920x1080@60
- install_full.sh cannot match the Orin Nano
“Cannot find the corresponding deb package” for kernel 6.8.12-tegra-39.2.1-20260806224157 on “NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super”. imx477_links.txt has an exactly matching kernel key, but only under orin_nx_* — no Orin Nano entry, so the board string never resolves. Manual dpkg -i of the t234-nx .deb works. (Line 19 also warns: command substitution: ignored null byte in input.)
INVALID_SETTING error log:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 !
“video/x-raw(memory:NVMM), width=1920, height=1080, framerate=60/1, format=NV12” !
nvvidconv ! ‘video/x-raw, format=BGRx’ !
queue ! videoconvert !
xvimagesink sync=false
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
CONSUMER: Waiting until producer is connected…
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Camera index = 0
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: INVALID_SETTINGS
Additional debug info:
Execution ended after 0:00:00.953495549
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline …
Hi @Dion,
Thanks for the update. I found your new *.deb in the download folder for the Jetson AGX Orin Dev Kit.
I have a Jetson OrinNano Super Dev Kit, so I assume the drive should be in this URL Release Jetson Orin NX · ArduCAM/MIPI_Camera · GitHub repository?
The latest entry I see is from September 29th. But—unless I’m mistaken—that one isn’t for the IMX519 camera and not for the Orin Nano Super?
Can you explain how I can proceed?
Thanks
Martin
Hi @martin
Yes, this link is for Jetson Orin Nano/NX.
We’ve already finished the IMX519 camera driver compatibility on L4T 39.2.1. However, we’re still figuring out how to edit the NITO file for the IMX519 camera cause the image quality is ewwww
You can downgrade your Jetson Orin Nano to L4T 36.5.0 which is fully compatible with the IMX519 camera.
