I get this error when changing the resolution to maximum 9152x6944 with this example GitHub - edward-ardu/libcamera-cpp-demo: libcamera c++ demo. Works fine with smaller resolutions. Also the libcamera-still utility also works fine capturing picture with max resolution.
[email protected]:~/libcamera-cpp-demo/build $ ./libcamera-demo
[0:09:29.626550460] [3199] INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4226-8689dd6b-dirty (2023-05-14T15:40:26+03:00)
[0:09:29.667717204] [3200] WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for 'arducam_64mp'
[0:09:29.668152881] [3200] WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:09:29.902760322] [3200] WARN RPI raspberrypi.cpp:1366 Mismatch between Unicam and CamHelper for embedded data usage!
[0:09:29.907371567] [3200] INFO RPI raspberrypi.cpp:1485 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media0 and ISP device /dev/media3
[0:09:29.912976144] [3200] WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for 'arducam_64mp'
[0:09:29.913310304] [3200] WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:09:30.039218952] [3200] WARN RPI raspberrypi.cpp:1366 Mismatch between Unicam and CamHelper for embedded data usage!
[0:09:30.042396317] [3200] INFO RPI raspberrypi.cpp:1485 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media1 and ISP device /dev/media4
Configuring still capture...
Stream configuration adjusted
Still capture setup complete
here1here2[0:09:30.046303019] [3199] INFO Camera camera.cpp:1028 configuring streams: (0) 9152x6944-RGB888
[0:09:30.047686530] [3200] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 9152x6944-SRGGB10_1X10 - Selected unicam format: 9152x6944-pRAA
[0:09:30.222518512] [3200] ERROR V4L2 v4l2_videodevice.cpp:1248 /dev/video14[15:cap]: Not enough buffers provided by V4L2VideoDevice
Can't allocate buffers
Hardware:
Pi4 CM4, 8GB, 2GB RAM
one quad arducam 64mp hat connected and one single arducam 64mp
Linux pi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
Also when i make 2 camera instances in my custom qt project that i built on this eduards libcamera-cpp-demo example and set the resolution to 4624x3472 and try to capture images from both cameras at the same time then i slightly diferent error:
"capture picture /base/soc/i2c0mux/[email protected]/[email protected]"
TRACE 2023-05-21T18:27:37.287 Capturing picture from the camera.
TRACE 2023-05-21T18:27:37.288 Temporary file for captured arducam image: "/home/pi/DigiCandy/[email protected][email protected]"
[0:21:13.851824512] [4502] INFO Camera camera.cpp:1028 configuring streams: (0) 4624x3472-RGB888
[0:21:13.853292029] [4514] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
frame read success
here2
TRACE 2023-05-21T18:27:39.355 Capturing picture from the camera.
TRACE 2023-05-21T18:27:39.355 Acquiring lock for taking a picture.
copyPicture filename= "[email protected][email protected]" target= "/home/pi/DigiCandy/[email protected][email protected]" target= "[email protected][email protected]"
TRACE 2023-05-21T18:27:39.356 Temporary file for captured arducam image: "/home/pi/DigiCandy/[email protected][email protected]"
[0:21:15.918567404] [4502] INFO Camera camera.cpp:1028 configuring streams: (0) 4624x3472-RGB888
[0:21:15.919464040] [4514] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/[email protected]/arducam_64mp[email protected] - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
[0:21:15.988949137] [4514] ERROR V4L2 v4l2_videodevice.cpp:1248 /dev/video21[44:cap]: Not enough buffers provided by V4L2VideoDevice
First camera can take the picture but the second camera gives the same error. If i decrease resolution further then both can take picture.
Just reminding this that with these commands capturing pictures works at max res
libcamera-still --camera 0 --width 9152 --height 6944 -o L.jpg -n
libcamera-still --camera 1 --width 9152 --height 6944 -o R.jpg -n
was 4 before. now the first camera can capture at max res but the second one still gives similar error. when attempting to capture with both cameras at the same time
TRACE 2023-05-21T18:39:14.289 Capturing picture from the camera.
TRACE 2023-05-21T18:39:14.290 Temporary file for captured arducam image: "/home/pi/DigiCandy/[email protected][email protected]"
[0:32:50.857012633] [5353] INFO Camera camera.cpp:1028 configuring streams: (0) 9152x6944-RGB888
[0:32:50.859709532] [5365] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 9152x6944-SRGGB10_1X10 - Selected unicam format: 9152x6944-pRAA
frame read success
here2
TRACE 2023-05-21T18:39:20.764 Acquiring lock for taking a picture.
TRACE 2023-05-21T18:39:20.764 Capturing picture from the camera.
TRACE 2023-05-21T18:39:20.764 Temporary file for captured arducam image: "/home/pi/DigiCandy/[email protected][email protected]"
[0:32:57.327364878] [5353] INFO Camera camera.cpp:1028 configuring streams: (0) 9152x6944-RGB888
[0:32:57.328435589] [5365] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 9152x6944-SRGGB10_1X10 - Selected unicam format: 9152x6944-pRAA
[0:32:57.331721150] [5365] ERROR V4L2 v4l2_videodevice.cpp:1241 /dev/video21[44:cap]: Unable to request 1 buffers: Cannot allocate memory
Based on our testing, we’ve found that saving a picture from one camera is consuming a significant amount of buffer resources. As a result, attempting to store pictures from two cameras simultaneously is causing a bottleneck in the system and resulting in insufficient buffer resources.
Currently saving two cameras at the same time is difficult, even if you use libcamera-still , you can use multithreading to save verification at the same time.
You can run the libcamera-still command with python using two threads to use two cameras at the same time to verify whether it is possible to save two cameras at the same time. I just want you to verify that it is not theoretically possible.
yes, i think u are right. the code i had wasnt really capturing images from 2 cameras at the same time but rather in series. when i tried to run them in separate threads. the first time I ran it actually captured from 2 cameras at the same time but didnt to so later so it was either a fluke or i dont know what happened. anyways i havent been able to repeat it.
Anyhow can you help me fixing the stride issue in my code that i mentioned in another forum thread? We have already bought 6 arducam 64mp cameras. We are developing a low-cost semi-automatic bookscanning machine. If we succeed with the development then it will go into production and we will be buying a lot more arducam cameras.
I have reviewed your code, but it’s difficult to diagnose what’s going on. Currently, my energy is limited as I have to maintain the existing warehouse and there is also a lot of development work to be done. I’m afraid I may not have enough time to assist you in finding out the reason.
ok, no worries. ill see if i can simplify the question and perhaps fork your sample code and recreate my problem there so it will be something u can simply compile and run.
i had to add if(!cam.camera_started_) cam.startCamera();
cause i called startCamera before making each picture
i found it out by experimenting with your libcamera-cpp-example. I think stopcamera is bugged.
cam.startCamera();
cam.VideoStream(&width, &height, &stride);
while (true) {
flag = cam.readFrame(&frameData);
if (!flag)
continue;
Mat im(height, width, CV_8UC3, frameData.imageData, stride);
imshow("libcamera-demo", im);
key = waitKey(1);
if (key == 'q') {
break;
} else if (key == 'f') {
ControlList controls;
controls.set(controls::AfMode, controls::AfModeAuto);
controls.set(controls::AfTrigger, 0);
cam.set(controls);
} else if (key == 'a' || key == 'A') {
lens_position += focus_step;
} else if (key == 'd' || key == 'D') {
lens_position -= focus_step;
// To use the manual focus function, libcamera-dev needs to be updated to version 0.0.10 and above.
if (key == 'a' || key == 'A' || key == 'd' || key == 'D') {
controls.set(controls::AfMode, controls::AfModeManual);
controls.set(controls::LensPosition, lens_position);
cam.set(controls);
frame_count++;
if ((time(0) - start_time) >= 1){
printf("fps: %d\n", frame_count);
frame_count = 0;
start_time = time(0);
cam.returnFrameBuffer(frameData);
break;
destroyAllWindows();
/* //uncomment this and it doesent work
cam.stopCamera();
cam.startCamera();
/* //uncomment this and it doesent work either
cam.startCamera();
while (true) {
if (!flag)
continue;
key = waitKey(1);
if (key == 'q') {
break;
cam.set(controls);
cam.set(controls);
frame_count++;
frame_count = 0;
break;
cam.stopCamera();
anyways i managed to fix the issue where i couldnt capture any pictures after first picture. but now the issue i face is that all following pictures are exact copy of the first one. so i added a counter that would only capture picture after reading certain amount of frames - this seems to be path to a solution
I forked your code and recreated there the error i get when attempting to capture images in series (not parallel) from 2 different arducam_64mp cameras at max resolution. I kept the imshow cause it doesent make a difference to write it in file with imwrite to demonstrate the error.
U can grab the code from
How to fix this? Capturing images in series at max res using libcamera-still command line works fine but not in you cpp-demo.
Now i tested again with your code i modified, im not getting the error anymore… very strange. But I still get the error in my QT application. could it be related to that my QT application is a lot larger and using a lot more memory on its own.
ok, i think its my QT code thats buggy not your code. i think im not doing everything in series instead im doing somethings still in paralell thats why i get this error. will figure this out tomorrow.
also we have figured out a solution how to capture 2 images at the same time at max res - we can just use 2 separate RPIs for each camera. one will run our QT app and the second one modified version of your libcamera-cpp-demo to capture second picture.
