I have a Multi-Camera Adapter Board V2.2 with four IMX219 Color Cameras connected to it and I have mounted the entire setup on Raspberry Pi 3b+ with the latest version of Buster OS.
I have followed all the steps mentioned in this link but could not see any address for $ i2cdetect -y 0.
And there seems to be no video0 device,
$ ls /dev/video0
ls: cannot access ‘/dev/video0’: No such file or directory
I ensured connections are correct and added dtparam=i2c_vc=on to /boot/config.txt and rebooted hardware. Could you please help me if I am missing anything?
Cannot open device /dev/video0, exiting.
pi@raspberrypi:~ $ ls /dev/video0
pi@raspberrypi:~ $
The log: “imx219 10-0010: failed to read chip id 219” means can’t detect the sensor. Most of time, it is due to the hardware connection,especially the powr en and i2c pins. Please ensure and check the csi cable line and change another cable line if you have extra one.
I am still seeing the same issue even after changing the cables for all cameras.
Can I connect these cameras directly to the Raspberry Pi CSI connector and check? Is it safe to do so? Because somewhere in the documentation I remember reading about one of the cameras doesn’t work with a direct connection to Raspberry Pi.
BTW I am using FFC Cable Type B, not sure if this is relevant just posting it here
The cable line is right. You can remove the adapter board and connect the camera to the PI’s CSI port directly.
Don’t worry and I will help you solve all of your issue.
Thanks a lot for volunteering to help me on this issue, and, sorry for my delayed response.
So far I have tried direct connection workflow (Camera → CSI of Raspberry Pi)on Raspberry Pi 3b+, B+, and Zero with Buster and Bullseye OS and I still see the same issue where dmesg says “imx219 10-0010: failed to read chip id 219”. Not sure what I am missing here.
Just an FYI, I am using IMX219 cameras from Camera Bundle Kit, not sure if this is causing the issue.
Oh,If you are using camarray, you can’t use the single camera, due to the hardware is specific. Please attach me your hardware picture, I need to ensure the camera you are using.
Oh my bad, didn’t realize that camarray cameras are not compatible with the multicam adapter boards. Thanks a lot for letting me know. Here is the picture of camera that I have,
Just another tiny help, can you please share the compatible cameraboard purchase links for the Multicamera adapter module v2.2 which I have? I really appreciate it if you could share the links, any 5/8MP cameras with basic functionality would do.
