Noobs Raspberry Pi not working with example Python/ OpenCV CV2 Error
  1. Where did you get the camera module(s)? Amazon
  2. Model number of the product(s)? Arducam 1MP OV9281, SKU: UB0232
  3. What hardware/platform were you working on? Raspberry Pi
    UVC Cameras on Linux - Command Line Operations - Arducam
and
  1. Problems you were having?
    Open CV issues
  2. The dmesg log from your hardware?
    ***@raspberrypi:~ $ dmesg
    [ 0.000000] Linux version 5.15.61-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 SMP Fri Aug 26 11:10:59 BST 2022
    [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
    18.720203] Bluetooth: RFCOMM socket layer initialized
    [ 18.720247] Bluetooth: RFCOMM ver 1.11
    [ 30.478830] logitech-hidpp-device 0003:046D:1025.0006: HID++ 1.0 device connected.
    [ 33.111983] cam-dummy-reg: disabling
    [ 434.807947] usb 1-1.4: USB disconnect, device number 6
    [ 437.154660] usb 1-1.4: new high-speed USB device number 8 using dwc_otg
    [ 437.301007] usb 1-1.4: New USB device found, idVendor=0c45, idProduct=6366, bcdDevice= 1.00
    [ 437.301059] usb 1-1.4: New USB device strings: Mfr=2, Product=1, SerialNumber=3
    [ 437.301081] usb 1-1.4: Product: Arducam OV9281 USB Camera
    [ 437.301098] usb 1-1.4: Manufacturer: Arducam Technology Co., Ltd.
    [ 437.301115] usb 1-1.4: SerialNumber: UC762
    [ 437.306517] usb 1-1.4: Found UVC 1.00 device Arducam OV9281 USB Camera (0c45:6366)
    [ 437.335276] input: Arducam OV9281 USB Camera: Ardu as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/input/input18
***@raspberrypi:~$
    Solved-
  2. What help do you need?
    No help- just providing feedback to maybe help someone else.
New NOOBS install on RPi on 11/1/2022
did sudo install of v4l utility as described at:
Plugged in Arducam UVC Cam OVC9281 into USB port
Verified the camera shows up in listed devices and detailed informaiton as described in the above page (video0)
Followed directions at:
to install openCV (CV2) libraries, i.e. in terminal:
$ pip install OpenCV-python
Copied simple python program from above web page into Thonny IDE and ran the code-
Get error-
%Run ArducamTest.py
File “/home/pi/PythonPrograms/ArducamTest.py”, line 1, in
import cv2
File “/home/pi/.local/lib/python3.9/site-packages/cv2/init.py”, line 181, in
bootstrap()
File “/home/pi/.local/lib/python3.9/site-packages/cv2/init.py”, line 153, in bootstrap
native_module = importlib.import_module(“cv2”)
File “/usr/lib/python3.9/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
ImportError: libcblas.so.3: cannot open shared object file: No such file or directory
Did some websearching… Need to install couple other items from terminal:
$ sudo apt-get install libjasper-dev
$ sudo apt-get install libatlas-base-dev
Again ran the ArducamTest.py code, progressed further, but get new error related to numpy:
RuntimeError: module compiled against API version 0xf but this version of numpy is 0xd
File “/home/pi/PythonPrograms/ArducamTest.py”, line 2, in
import cv2
bootstrap()
ImportError: numpy.core.multiarray failed to import
So did update of Numpy library:
$ sudo pip3 install numpy --upgrade
Running the Python code now works!
The program runs OK (With washed out/too bright image) but generally fine.
Hope this can save someone some time.
