Ultronics
IMX 477 12mp SKU BO241
Raspberry Pi 4B 8GB with mos current raspian image
NO
The 8gb Pi is brand new and the SD is newly created.
From the command line I try raspistill -t 10000
I get a ten second delay but no image.
The camera is detected. If I remove the cable i get the error that no device is found.
The camera is enabled, I have 128 mb set for the GPU.
Is there something else I am forgetting?
I changed the ribbon cable No luck
Suggest some fixes and test procedures
