Hi everyone, I’m stuck trying to get a BO484 Multi-Camera Array Module working on a Raspberry Pi 5. I followed the guide at libcamera and rpicam-apps - Arducam Wiki and ran:
I get this output:
[0:00:27.623276112] [1470] INFO Camera camera_manager.cpp:284 libcamera v0.2.0+46-075b54d5
Made X/EGL preview window
Is this the correct method for the Multi-Camera Array Module? Any idea what the error means or how to fix it?
Can you post a couple of photos of the hardware connection? One of the Raspberry Pi end and one of the camera end. On a Pi 5 with libcamera v0.2.0, that ‘no cameras available’ error usually means libcamera isn’t detecting the camera at all, so I want to rule out the physical connection first.
Done. I rebooted, ran the tool, and it created the file. I also re-ran libcamera-jpeg -o test.jpg and still get the same *** no cameras available *** error.
I can see the issue in the bug report. The camera overlay is set to dtoverlay=imx708 without a camera instance. On the Pi 5, the imx708 needs the instance specified or libcamera won’t recognize the camera.
Try this:
In the config file, change dtoverlay=imx708 to dtoverlay=imx708,cam0.
Reboot the Pi 5.
Run libcamera-jpeg -o test.jpg again after boot and see if it’s detected.
