I’ve got an Arducam B0397 IMX477 stereo array on a Jetson Xavier NX Developer Kit, and I can’t get any image out of /dev/video0. I’ve tried gstreamer, opencv, ffplay, and vlc - nothing shows a frame.
Gstreamer does detect video0, but the sensor modes/resolutions it reports are completely different from the Arducam quick start tutorial. And sometimes it just dies with:
nvbuf_utils: Can not get HW buffer from FD… Exiting…
Can you share your Jetpack/L4T version and the output of uname -a? Also, how did you configure the board - did you use jetson-io.py? And what does v4l2-ctl --list-devices show when /dev/video0 is present?
Your kernel 5.10.104-tegra-35.1.0 is Jetpack 5.x. On that version the Arducam install script fails with “Cannot find the corresponding deb package, please send the following information to Arducam support” - basically there is no matching deb for your release, so the driver never gets set up correctly.
I’d suggest downgrading to Jetpack 4.6.2 (R32.7.2) and running the imx477_stereo install script there.
That output is the key clue. It’s probing imx219, not imx477 - the wrong sensor driver is being loaded. Both I2C addresses (9-0010 and 10-0010) fail board setup with read probe error -121, which means the IMX477 is not being detected/configured at all.
Arducam’s troubleshooting page explains this check: if your dmesg output matches their expected figure, the IMX-477 driver is installed; if it shows imx219 or “arducam” instead, the wrong driver is installed.
Okay so 10-001a bound successfully, but 9-001a still fails the I2C read probe with -121. That’s one of the two cameras on the array not coming up. Let’s still see the gstreamer log - the nvarguscamerasrc output will tell us what modes the bound camera is exposing.
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
CONSUMER: Waiting until producer is connected…
GST_ARGUS: 4056 x 3040 FR = 10.000000 fps Duration = 100000000 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 2028 x 1520 FR = 40.000000 fps Duration = 25000000 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 2028 x 1080 FR = 50.000000 fps Duration = 20000000 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings: Camera index = 0, Camera mode = 2, Output Stream W = 2028 H = 1080, seconds to Run = 0, Frame Rate = 50.000000
CONSUMER: Done Success
Got EOS from element “pipeline0”.
Execution ended after 0:00:04.004534720
Setting pipeline to READY …
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Setting pipeline to NULL …
Freeing pipeline …
So the sensor modes don’t match what the IMX477 driver should be exposing. Combined with 9-001a failing -121 and the nvbuf_utils dmabuf_fd -1 error, the camera isn’t being set up correctly.
I think the root cause is a known Jetpack 4.6.2 bug: cboot in R32.7.2 fails to read extlinux.conf. That’s why after installing imx477_stereo on 4.6.2, dmesg still showed imx219 being probed - the correct DTB wasn’t actually being applied.
See this NVIDIA forum thread for the details and the cboot fix:
The options are:
Compile and replace cboot as described in that thread.
Rewrite the system using SDKmanager.
The simplest workaround: switch to a different Jetpack version.
On 4.6.1 the driver situation improved (imx477 on 10-001a, /dev/video0 present), but you still have 9-001a failing the I2C read probe with -121 and the sensor modes/nvbuf_utils failure. So the current conclusion is that the 4.6.2 cboot bug is the underlying cause, and the cleanest path is to change the Jetpack version, or apply the cboot fix and reflash.
