No camera enable option in raspi-config for Arducam 5 on Pi 4B
Hey everyone, hoping someone can help me figure this out. I’ve got a Raspberry Pi 4B and just hooked up an Arducam 5MP camera module (the OV5647 one) using the FFC ribbon cable. The physical connection looks fine — cable is seated properly at both ends. I booted up, went into raspi-config to enable the camera, and… there’s literally no camera option anywhere. Checked Interface Options — nothing. Checked Advanced Options — also nothing. The Pi just doesn’t seem to know the camera is there at all. Anyone seen this before?
Which version of Raspberry Pi OS are you running? If you’re on Bullseye or Bookworm, the camera enable toggle was actually removed from raspi-config because the legacy camera stack has been deprecated. That would explain why it’s missing from both Interface Options and Advanced Options. Can you run cat /etc/os-release and share what it says?
Yeah, it’s Bullseye. Here are screenshots of what I’m seeing — Interface Options menu, no camera entry at all, and same deal under Advanced Options, completely missing. I’ve reseated the FFC cable twice just to rule that out. So if the legacy camera stack is gone in Bullseye, how do I actually get this OV5647 working? Is there a different way to enable it now?
That confirms it — on Bullseye and newer, the old raspi-config camera toggle is gone. The Arducam 5MP OV5647 doesn’t get auto-detected just by connecting the FFC cable either; it needs some manual config. You’ve got two potential paths here:
  1. libcamera (the default on Bullseye) — you’ll need to add the correct dtoverlay line in /boot/config.txt. This is the recommended approach going forward.
  2. Legacy camera stack — you could re-enable it, but it’s deprecated and I wouldn’t suggest it unless you have a specific reason.
The official Arducam getting-started guide for the 5MP OV5647 covers the exact dtoverlay and steps: 5MP OV5647 - Arducam Wiki
Give that a read — it’ll have the specific dtoverlay line you need to drop into config.txt. You’ll probably also want to make sure I2C is enabled (raspi-config → Interface Options → I2C, which should still be there).
Okay, that makes sense now. So just to be clear — on Bullseye the camera toggle in raspi-config is straight-up removed and it’s not coming back, right? We’re supposed to use dtoverlay in /boot/config.txt instead? I’ll go through that Arducam guide and add whatever dtoverlay it specifies. I checked and I2C is already enabled on my end. Will report back after I edit config.txt and reboot.
Exactly right. The camera interface toggle was removed from raspi-config starting with Bullseye — it’s not a bug, it’s intentional. All camera configuration now goes through /boot/config.txt via dtoverlay entries.
For your OV5647, once you’ve added the correct dtoverlay from the Arducam docs and rebooted, you can test with:
or
libcamera-vid -t 5000 -o test.h264
If it still doesn’t show up after that, run sudo i2cdetect -y 1 and check whether the sensor appears on the I2C bus — that’ll tell you if it’s a connection/hardware issue vs. a config problem. But the dtoverlay step is the key one that’s missing right now.
