No AF algorithm for imx519
Have you ever installed the libcamera of the Arducam version?
Besides, if you still have the same error log like “no AF algorithm” after installing the libcamera, could you please post the output of the command below?
dpkg -l | grep libcamera
Hi Dion, Yes I have installed the libcamera of the Arducam version.
Running:
Returns:
ii libcamera-apps 1.5.3-1 all transitional package
ii libcamera-dev:arm64 0.3.2+rpt20241119-1 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.3.2+rpt20241119-1 arm64 complex camera support library (IPA modules)
ii libcamera0.3:arm64 0.3.2+rpt20241119-1 arm64 complex camera support library
ii python3-libcamera:arm64 0.3.2+rpt20241119-1 arm64 complex camera support library (Python bindings)
Hi @Razzbiz
It appears that you didn’t manage to install the Aruducam libcamera. See the screenshot below which shows the correct version.
Suggest that you run the commands below again.
./install_pivariety_pkgs.sh -l
Hi Dion, I have tried that approach many times without success.
I cant seem to add any kind of meaningful amount of text to this reply. Constantly getting error 403
Hi @Razzbiz
You can post it on Google Driver or Dropbox.
Can you also post the output of the command below?
uname -a
Hi Dion,
This is the result of running uname -a
Linux PICAM-RIG1-A2 6.6.62+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
I still need the error logs when you install the Arducam libcamera.
Please attach them in the google drive or other file server.
