dmesg
[ 0.000000] Linux version 5.15.32-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP Thu Mar 31 19:39:41 BST 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:23:9B:C8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=afd608c0-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3601320K/4050944K available (10240K kernel code, 1390K rwdata, 3292K rodata, 2048K init, 590K bss, 121944K reserved, 327680K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 35355 entries in 104 pages
[ 0.000000] ftrace: allocated 104 pages with 3 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[ 0.000000] random: get_random_bytes called from start_kernel+0x574/0x758 with crng_init=1
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000022] Switching to timer-based delay loop, resolution 18ns
[ 0.000315] Console: colour dummy device 80x30
[ 0.001035] printk: console [tty1] enabled
[ 0.001112] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001165] pid_max: default: 32768 minimum: 301
[ 0.001321] LSM: Security Framework initializing
[ 0.001492] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001540] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003101] cgroup: Disabling memory control group subsystem
[ 0.003360] CPU: Testing write buffer coherency: ok
[ 0.003431] CPU0: Spectre BHB: using loop workaround
[ 0.003889] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005129] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005366] rcu: Hierarchical SRCU implementation.
[ 0.006320] smp: Bringing up secondary CPUs ...
[ 0.007525] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007542] CPU1: Spectre BHB: using loop workaround
[ 0.008878] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008895] CPU2: Spectre BHB: using loop workaround
[ 0.010267] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010285] CPU3: Spectre BHB: using loop workaround
[ 0.010472] smp: Brought up 1 node, 4 CPUs
[ 0.010508] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010541] CPU: All CPU(s) started in HYP mode.
[ 0.010568] CPU: Virtualization extensions available.
[ 0.011349] devtmpfs: initialized
[ 0.026711] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026963] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027020] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.036718] pinctrl core: initialized pinctrl subsystem
[ 0.037984] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.042503] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.043314] audit: initializing netlink subsys (disabled)
[ 0.043582] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.044198] thermal_sys: Registered thermal governor 'step_wise'
[ 0.044875] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.044933] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.045352] Serial: AMBA PL011 UART driver
[ 0.059996] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.100048] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
[ 0.110065] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.169787] Kprobes globally optimized
[ 0.175365] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.179991] vgaarb: loaded
[ 0.180785] SCSI subsystem initialized
[ 0.181041] usbcore: registered new interface driver usbfs
[ 0.181149] usbcore: registered new interface driver hub
[ 0.181238] usbcore: registered new device driver usb
[ 0.181669] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.182161] pps_core: LinuxPPS API ver. 1 registered
[ 0.182192] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.182255] PTP clock support registered
[ 0.183852] clocksource: Switched to clocksource arch_sys_counter
[ 0.264540] VFS: Disk quotas dquot_6.6.0
[ 0.264669] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.264867] FS-Cache: Loaded
[ 0.265064] CacheFiles: Loaded
[ 0.274371] NET: Registered PF_INET protocol family
[ 0.274643] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.276257] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.276315] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.276402] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.276495] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.276672] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.276732] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.277006] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.278042] RPC: Registered named UNIX socket transport module.
[ 0.278078] RPC: Registered udp transport module.
[ 0.278106] RPC: Registered tcp transport module.
[ 0.278133] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.278169] PCI: CLS 0 bytes, default 64
[ 1.135183] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.137878] Initialise system trusted keyrings
[ 1.138167] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.147280] zbud: loaded
[ 1.149274] FS-Cache: Netfs 'nfs' registered for caching
[ 1.150180] NFS: Registering the id_resolver key type
[ 1.150243] Key type id_resolver registered
[ 1.150271] Key type id_legacy registered
[ 1.150424] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.150458] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.151586] Key type asymmetric registered
[ 1.151618] Asymmetric key parser 'x509' registered
[ 1.151863] bounce: pool size: 64 pages
[ 1.151939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.152176] io scheduler mq-deadline registered
[ 1.152208] io scheduler kyber registered
[ 1.161243] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.161308] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.161423] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.161542] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.225959] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.226388] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.226424] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.226461] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.226573] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.226835] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.230643] PCI: bus0: Fast back to back transfers disabled
[ 1.230996] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.231140] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.231593] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.235423] PCI: bus1: Fast back to back transfers disabled
[ 1.235500] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.235543] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.235648] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.235687] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.236115] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.236366] pcieport 0000:00:00.0: PME: Signaling with IRQ 79
[ 1.249680] iproc-rng200 fe104000.rng: hwrng registered
[ 1.250099] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.251684] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.264613] brd: module loaded
[ 1.274969] loop: module loaded
[ 1.275778] Loading iSCSI transport class v2.0-870.
[ 1.281012] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.374021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.375257] usbcore: registered new interface driver r8152
[ 1.375345] usbcore: registered new interface driver lan78xx
[ 1.375461] usbcore: registered new interface driver smsc95xx
[ 1.423190] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.423245] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.428950] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.430315] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.430362] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.430401] usb usb1: Product: xHCI Host Controller
[ 1.430432] usb usb1: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.430463] usb usb1: SerialNumber: 0000:01:00.0
[ 1.431208] hub 1-0:1.0: USB hub found
[ 1.431323] hub 1-0:1.0: 1 port detected
[ 1.432014] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.432058] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.432115] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.432597] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.432641] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.432679] usb usb2: Product: xHCI Host Controller
[ 1.432710] usb usb2: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
[ 1.432741] usb usb2: SerialNumber: 0000:01:00.0
[ 1.433466] hub 2-0:1.0: USB hub found
[ 1.433554] hub 2-0:1.0: 4 ports detected
[ 1.435444] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.435841] dwc_otg: FIQ enabled
[ 1.435856] dwc_otg: NAK holdoff enabled
[ 1.435869] dwc_otg: FIQ split-transaction FSM enabled
[ 1.435886] Module dwc_common_port init
[ 1.436350] usbcore: registered new interface driver uas
[ 1.436496] usbcore: registered new interface driver usb-storage
[ 1.436722] mousedev: PS/2 mouse device common for all mice
[ 1.442296] sdhci: Secure Digital Host Controller Interface driver
[ 1.442334] sdhci: Copyright(c) Pierre Ossman
[ 1.443115] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.447038] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.447402] hid: raw HID events driver (C) Jiri Kosina
[ 1.447617] usbcore: registered new interface driver usbhid
[ 1.447649] usbhid: USB HID core driver
[ 1.455454] Initializing XFRM netlink socket
[ 1.455519] NET: Registered PF_PACKET protocol family
[ 1.455649] Key type dns_resolver registered
[ 1.456018] Registering SWP/SWPB emulation handler
[ 1.456856] registered taskstats version 1
[ 1.456900] Loading compiled-in X.509 certificates
[ 1.457799] Key type ._fscrypt registered
[ 1.457831] Key type .fscrypt registered
[ 1.457859] Key type fscrypt-provisioning registered
[ 1.470343] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.470704] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.470871] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 1.480262] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.480767] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.482064] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.482102] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.512448] of_cfs_init
[ 1.512711] of_cfs_init: OK
[ 1.547746] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.548080] Waiting for root device PARTUUID=afd608c0-02...
[ 1.612545] mmc1: new high speed SDIO card at address 0001
[ 1.663959] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.664888] mmcblk0: mmc0:0001 SD32G 29.1 GiB
[ 1.668353] mmcblk0: p1 p2
[ 1.668927] mmcblk0: mmc0:0001 SD32G 29.1 GiB
[ 1.704516] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.704628] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.710236] devtmpfs: mounted
[ 1.713904] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.721931] Freeing unused kernel image (initmem) memory: 2048K
[ 1.744189] Run /sbin/init as init process
[ 1.744220] with arguments:
[ 1.744233] /sbin/init
[ 1.744246] with environment:
[ 1.744259] HOME=/
[ 1.744271] TERM=linux
[ 1.896531] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.896593] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.896630] usb 1-1: Product: USB2.0 Hub
[ 1.898793] hub 1-1:1.0: USB hub found
[ 1.899162] hub 1-1:1.0: 4 ports detected
[ 2.112208] systemd[1]: System time before build time, advancing clock.
[ 2.236318] NET: Registered PF_INET6 protocol family
[ 2.238026] Segment Routing with IPv6
[ 2.238107] In-situ OAM (IOAM) with IPv6
[ 2.306358] systemd[1]: systemd 247.3-7+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.307275] systemd[1]: Detected architecture arm.
[ 2.320712] systemd[1]: Set hostname to <Picamera2RPi>.
[ 3.189527] systemd[1]: Queued start job for default target Multi-User System.
[ 3.191014] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.195339] systemd[1]: Created slice system-getty.slice.
[ 3.196141] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.197244] systemd[1]: Created slice system-modprobe.slice.
[ 3.197684] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.198695] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.199935] systemd[1]: Created slice User and Session Slice.
[ 3.200767] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.201534] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.202947] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.203612] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.204449] systemd[1]: Reached target Paths.
[ 3.205003] systemd[1]: Reached target Slices.
[ 3.205494] systemd[1]: Reached target Swap.
[ 3.206967] systemd[1]: Listening on Syslog Socket.
[ 3.208050] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.208808] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.210266] systemd[1]: Listening on Journal Audit Socket.
[ 3.211361] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.212690] systemd[1]: Listening on Journal Socket.
[ 3.218930] systemd[1]: Listening on udev Control Socket.
[ 3.220136] systemd[1]: Listening on udev Kernel Socket.
[ 3.221337] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.226873] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.233335] systemd[1]: Mounting RPC Pipe File System...
[ 3.240434] systemd[1]: Mounting Kernel Debug File System...
[ 3.248259] systemd[1]: Mounting Kernel Trace File System...
[ 3.249312] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.260909] systemd[1]: Starting Restore / save the current clock...
[ 3.271556] systemd[1]: Starting Set the console keyboard layout...
[ 3.279719] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.287850] systemd[1]: Starting Load Kernel Module configfs...
[ 3.295762] systemd[1]: Starting Load Kernel Module drm...
[ 3.304387] systemd[1]: Starting Load Kernel Module fuse...
[ 3.308720] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.316612] systemd[1]: Starting File System Check on Root Device...
[ 3.329614] systemd[1]: Starting Journal Service...
[ 3.340033] systemd[1]: Starting Load Kernel Modules...
[ 3.347911] systemd[1]: Starting Coldplug All udev Devices...
[ 3.361553] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.362787] systemd[1]: Mounted RPC Pipe File System.
[ 3.376097] fuse: init (API version 7.34)
[ 3.377753] systemd[1]: Mounted Kernel Debug File System.
[ 3.394300] systemd[1]: Mounted Kernel Trace File System.
[ 3.397774] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.407327] systemd[1]: [email protected]: Succeeded.
[ 3.436042] systemd[1]: Finished Load Kernel Module configfs.
[ 3.440925] systemd[1]: Finished Restore / save the current clock.
[ 3.447659] systemd[1]: [email protected]: Succeeded.
[ 3.449328] systemd[1]: Finished Load Kernel Module fuse.
[ 3.452275] systemd[1]: [email protected]: Succeeded.
[ 3.453809] systemd[1]: Finished Load Kernel Module drm.
[ 3.457251] systemd[1]: Finished Load Kernel Modules.
[ 3.469773] systemd[1]: Mounting FUSE Control File System...
[ 3.481823] systemd[1]: Mounting Kernel Configuration File System...
[ 3.501164] systemd[1]: Started File System Check Daemon to report status.
[ 3.517292] systemd[1]: Starting Apply Kernel Variables...
[ 3.527650] systemd[1]: Mounted FUSE Control File System.
[ 3.528736] systemd[1]: Mounted Kernel Configuration File System.
[ 3.585667] systemd[1]: Finished Apply Kernel Variables.
[ 3.642242] systemd[1]: Finished File System Check on Root Device.
[ 3.648802] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.708224] systemd[1]: Started Journal Service.
[ 3.834519] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 3.904662] systemd-journald[136]: Received client request to flush runtime journal.
[ 3.915143] systemd-journald[136]: File /var/log/journal/ea4098166ed94a599a325835691f5c38/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.854943] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.905018] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.939818] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.953427] mc: Linux media interface: v0.10
[ 4.957733] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.017097] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.019704] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.019732] [vc_sm_connected_init]: start
[ 5.032693] [vc_sm_connected_init]: installed successfully
[ 5.050970] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.065656] videodev: Linux video capture interface: v2.00
[ 5.163503] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.166997] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.190039] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.269506] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.286943] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.289385] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.326377] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.327394] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.359785] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.364735] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.369719] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.370934] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.374460] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.388787] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.388882] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.388961] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.389037] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.389108] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.390896] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 5.391746] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.453583] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.472820] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.472893] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.480386] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.484884] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.484932] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.485961] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.506284] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.506345] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.506372] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.506396] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.506419] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.506717] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.506832] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.507225] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.522837] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.522893] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.588199] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.603811] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.611031] Registered IR keymap rc-cec
[ 5.656483] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 5.656598] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 5.684151] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.684862] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 6.122304] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.135668] Registered IR keymap rc-cec
[ 6.159898] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.306424] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 6.378159] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.423503] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.440768] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 6.707239] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.721000] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.731326] Registered IR keymap rc-cec
[ 6.738824] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.739986] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 6.746818] usbcore: registered new interface driver brcmfmac
[ 6.784587] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.893887] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 7.000479] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.000629] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.006353] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.156047] random: crng init done
[ 7.156065] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.177571] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.195788] Registered IR keymap rc-cec
[ 7.195985] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.196241] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
[ 7.420972] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.432147] Registered IR keymap rc-cec
[ 7.432374] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.432625] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[ 7.449910] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.472299] Registered IR keymap rc-cec
[ 7.472514] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.472775] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
[ 7.593299] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.594163] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.594668] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.595096] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.595514] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.595853] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.596318] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.699927] ak7375: loading out-of-tree module taints kernel.
[ 7.713795] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.714485] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 7.837378] imx519 10-001a: Device found is imx519
[ 7.843219] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 7.956130] uart-pl011 fe201000.serial: no DMA platform data
[ 8.221913] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.525680] 8021q: 802.1Q VLAN Support v1.8
[ 8.848003] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.125410] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.125915] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.291990] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.654075] Bluetooth: Core ver 2.22
[ 14.654166] NET: Registered PF_BLUETOOTH protocol family
[ 14.654176] Bluetooth: HCI device and connection manager initialized
[ 14.654197] Bluetooth: HCI socket layer initialized
[ 14.654210] Bluetooth: L2CAP socket layer initialized
[ 14.654232] Bluetooth: SCO socket layer initialized
[ 14.662038] Bluetooth: HCI UART driver ver 2.3
[ 14.662056] Bluetooth: HCI UART protocol H4 registered
[ 14.662130] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.662375] Bluetooth: HCI UART protocol Broadcom registered
[ 14.968849] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.968861] Bluetooth: BNEP filters: protocol multicast
[ 14.968872] Bluetooth: BNEP socket layer initialized
[ 14.980628] NET: Registered PF_ALG protocol family
[ 14.996884] cryptd: max_cpu_qlen set to 1000
[ 31.833931] cam-dummy-reg: disabling
