New Firmware Request for Arducam IMX477 UVC Camera Adapter Board Max Exposure
Hi, I need a firmware update for the Arducam IMX477 UVC Camera Adapter Board. Specifically I’m trying to get Max Exposure time working on it. Right now the exposure control caps out way earlier than I need, and I read somewhere that there’s a firmware version that unlocks longer exposure times. Does anyone know where to get it, or is it something support provides? I originally wrote to sales and support about this but wasn’t sure which channel handles it.
Hi, thanks for posting. Max Exposure on the IMX477 UVC adapter is a bit of a special case, so let’s narrow a couple things down first. Can you tell me:
  1. Which exact adapter board revision you have (UVC Camera Adapter Board, standard or the one with the external trigger/clock header).
  2. What host system you’re running it on, and which tool you use to set exposure (v4l2-ctl, OpenCV, custom UVC app, etc.).
  3. What the current max exposure value looks like for you, so we can tell how far off it is.
If you can run v4l2-ctl --list-ctrls --device=/dev/video0 and paste the exposure-related lines, that would help a lot.
Sure. It’s the standard IMX477 UVC Camera Adapter Board (the one for the Pi HQ camera basically). Host is Ubuntu 20.04 on a Pi 4. I’m controlling it with v4l2-ctl.
Here’s what I get for the controls:
exposure_auto (menu) : min=0 max=3 default=3 value=1
exposure_absolute (int) : min=4 max=65635 step=1 default=400 value=400
exposure_auto_priority (bool) : default=0 value=0
When I try to push exposure_absolute higher to get a long exposure, it just clamps and I don’t get the longer integration times I need. I need exposures in the multi-second range for low light work. Is there a firmware that raises that max?
Good, that output actually tells us a fair amount. The exposure_absolute max of 65635 is what the standard UVC firmware reports, and that ceiling is exactly the thing the custom Max Exposure firmware changes. The standard firmware isn’t built for multi-second integration on this board.
Before we point you at the right place, two quick things to confirm:
  • Make sure exposure_auto is set to 3 (manual) when you test, otherwise the auto algorithm fights your manual value.
  • Try v4l2-ctl -d /dev/video0 --set-ctrl=exposure_auto=3 then set your exposure_absolute value and see if the long value actually sticks in --list-ctrls afterward.
If it still clamps even in manual mode, then it’s a firmware limitation, not a host-side setting.
Tested it. With exposure_auto=3 the value does stick in the list, so it’s not being ignored, but I still don’t get true long exposures out of it. Anything above the usual range just looks like a normal exposure, not the multi-second integration I’m after. So I’m guessing it really is the firmware.
Is the Max Exposure firmware something I download somewhere, or does it come from a specific team? I sent a request to sales and support already but I want to make sure I’m going through the right path.
Quick follow up, I tried re-flashing the adapter with the latest firmware from the usual product page and reran the same v4l2-ctl tests. Same result, exposure still caps out the same way. So the public firmware doesn’t include the Max Exposure behavior. What’s the correct route to get the special firmware?
That confirms it. The Max Exposure build is a specific/custom firmware for the IMX477 UVC Camera Adapter Board and it isn’t distributed through the support channel or the normal product download page. Requests for those specific firmware builds are handled over on the sales side rather than support.
One note since some people get bounced around: this isn’t a case you can fix with a driver or kernel change on the Pi. The limitation lives in the UVC firmware on the adapter board itself, which is why re-flashing with the standard release didn’t change anything.
Summary of where this lands:
  • Board: Arducam IMX477 UVC Camera Adapter Board
  • Symptom: exposure_absolute reports max=65635 and clamps; long/multi-second exposure not achievable, even with exposure_auto=3 and even after re-flashing the standard firmware.
  • Conclusion: this needs the specific Max Exposure firmware, which support does not distribute directly.
Action: please reach out to the sales team at [email protected] and ask specifically for the Max Exposure firmware for the IMX477 UVC Camera Adapter Board. They own the distribution of that build.
If you get the firmware from them and run into trouble applying it, come back here and we can walk through the flashing process and re-check the v4l2-ctl output. But as far as the exposure ceiling itself goes, the fix is getting that build from sales.
