Need OV9281 - B0405 installation document
    uctronics.com
    OV9281 - B0405
    RPI 4
  4. What help do you need?
    I cannot find installation document for this camera. I need to use it with openCV.
OV9281 does not need to install the driver.
If you want to use opencv:
Thanks for your reply. I ran your code, I got the following error:
modulenotfounderror no module named ‘picamera2’
Just in case, this is what I have in config.txt file:
Raspberry Pi Documentation - Configuration
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
display_auto_detect=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
#dtoverlay=ov9281
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=ov9281
