2. Model number of the product(s)?
IMX519 Camera Module, 16MP Autofocus (4 pcs)
CamArray HAT (UC-512 REV.D1)
3. What hardware/platform were you working on?
Raspberry Pi Model 4B, 8GB RAM, Raspian Buster OS
4. Instructions you have followed. (link/manual/etc.)
No success, then:
5. Problems you were having?
Various, but all to do with not recognizing cameras/camarray
MIPI Driver installs fine, but then:
Hardware version: d03114
Camera Status: 4100
OBISP Driver installs fine, but returns:
ls: cannot access ‘/dev/video0’: No such file or directory
Troubleshooting attempts you’ve made?
Started in Bullseye, had trouble installing drivers, re-formated memory card with Buster, installed OpenCV, drivers installing fine now, however, CamArray & Cameras still not recognized
What help do you need?
Please supply tutorial to set up 4 16MP autofocus ArduCams with CamArray HAT on Raspberry Pi 4 B, Buster OS
These instructinos already iclude the low speed driver.
And the Camera is deteced, but doesn’t take any pictures. I’m getting the following error messages. can someone please help?
My System runs on a Raspberry Zero 2 W with IMX519 Camera Module, 16MP Autofocus (4 pcs)
Here are the Error messages I get:
libcamera-still -t 0 --camera 0
Preview window unavailable
[0:01:58.215284889] [1585] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:01:58.236750825] [1587] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ‘imx519’
[0:01:58.236842128] [1587] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:01:58.237901669] [1587] ERROR CameraSensor camera_sensor.cpp:591 ‘imx519 10-001a’: Camera sensor does not support test pattern modes.
[0:01:58.289258413] [1587] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:01:58.290275819] [1587] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:01:58.290920304] [1587] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media1
[0:01:58.292076201] [1585] INFO Camera camera.cpp:1029 configuring streams: (0) 2328x1748-YUV420
[0:01:58.292870844] [1587] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
^C [email protected]:~ $ libcamera-still -t 0
[0:02:32.105812634] [1714] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:02:32.126958461] [1716] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ‘imx519’
[0:02:32.127049972] [1716] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:02:32.128106904] [1716] ERROR CameraSensor camera_sensor.cpp:591 ‘imx519 10-001a’: Camera sensor does not support test pattern modes.
[0:02:32.179476724] [1716] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:02:32.180502041] [1716] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:02:32.181163346] [1716] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media1
[0:02:32.182263351] [1714] INFO Camera camera.cpp:1029 configuring streams: (0) 2328x1748-YUV420
[0:02:32.183083876] [1716] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
^C [email protected]:~ $ libcamera-still -t 0 -n
[0:02:41.935603800] [1766] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:02:41.956968883] [1768] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ‘imx519’
[0:02:41.957061071] [1768] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:02:41.958293784] [1768] ERROR CameraSensor camera_sensor.cpp:591 ‘imx519 10-001a’: Camera sensor does not support test pattern modes.
[0:02:42.010647531] [1768] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:02:42.011760347] [1768] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:02:42.012536340] [1768] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media1
[0:02:42.013640667] [1766] INFO Camera camera.cpp:1029 configuring streams: (0) 2328x1748-YUV420
[0:02:42.015177184] [1768] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:06:58.256619873] [1768] WARN V4L2 v4l2_videodevice.cpp:1952 /dev/video0[14:cap]: Dequeue timer of 255920000.00us has expired!
[0:06:58.256861644] [1768] ERROR RPI raspberrypi.cpp:1877 Unicam has timed out!
[0:06:58.256946123] [1768] ERROR RPI raspberrypi.cpp:1878 Please check that your camera sensor connector is attached securely.
[0:06:58.257031748] [1768] ERROR RPI raspberrypi.cpp:1879 Alternatively, try another cable and/or sensor.
Yes I am connected to the raspberry pi zero via ssh.
I’ve attached a picture of how the camarray HAT is wired up. I needed to use this extender/ adapter as I could not find any cable that connects between the 22pin to 22pin ribbon cable. Could that be the issue?
thanks for your replay. Unfortunately I was out of town and couldn’t work on the project. So the problem still persists but this topic got marked as solved which is not true.
I’ve tried out your suggestion to use: export DISPLAY=:0
But unfortunately this didn’t change anything.
Any more leads to what could be going wrong?
thank you.
Ive attached my Log from the command Promt: [email protected]:~ $ export DISPLAY=:0; libcamera-still --list-cameras
[0:10:09.122120184] [3236] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:10:09.143331245] [3237] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ‘imx519’
[0:10:09.143482025] [3237] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:10:09.144655347] [3237] ERROR CameraSensor camera_sensor.cpp:591 ‘imx519 10-001a’: Camera sensor does not support test pattern modes.
[0:10:09.196547592] [3237] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:10:09.197673363] [3237] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:10:09.198420231] [3237] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media0
Available cameras
0 : imx519 [4656x3496] (/base/soc/i2c0mux/[email protected]/[email protected])
Modes: ‘SRGGB10_CSI2P’ : 1280x720 1920x1080 2328x1748 3840x2160 4656x3496 [email protected]:~ $ export DISPLAY=:0; libcamera-still -t 0
Made X/EGL preview window
[0:10:36.180666399] [3321] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:10:36.206208109] [3346] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ‘imx519’
[0:10:36.206333317] [3346] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:10:36.207953459] [3346] ERROR CameraSensor camera_sensor.cpp:591 ‘imx519 10-001a’: Camera sensor does not support test pattern modes.
[0:10:36.276782511] [3346] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:10:36.277761409] [3346] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:10:36.278428747] [3346] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media0
[0:10:36.279572019] [3321] INFO Camera camera.cpp:1029 configuring streams: (0) 2048x1536-YUV420
[0:10:36.280408991] [3346] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
