Need ArduCam IMX477 .deb driver for Jetson Orin Nano L4T 36.5.0
Hi, I just got the ArduCam IMX477 Autofocus HQ Camera B0273 for my Jetson Orin Nano 8GB Developer Kit. I’m running JetPack 6.2.2 with L4T R36.5.0 and kernel 5.15.185-tegra. I downloaded the latest release v0.0.1-orin-nano from your GitHub, but it only seems to support up to kernel 5.15.122 / L4T 36.2.0. Can you point me to the correct .deb file for my kernel version?
Thanks for reaching out! I looked into this and it turns out the Jetson Orin Nano and Jetson Orin NX share the same camera driver. So even though the release is labeled ‘orin-nx’, it’s fully compatible with the Orin Nano. The v0.0.1-orin-nx release supports kernel 5.15.185-tegra, which is exactly what you have.
You can download and install it from here:
https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.1-orin-nx/arducam-nvidia-l4t-kernel-t234-nx-5.15.185-tegra-36.5.0-20260207170705_arm64_imx477.deb
Give that a try and let me know how it goes!
Okay, I installed that driver and the camera does stream now — I can see video feed coming through. But the image is completely blurry. I checked all the I2C buses and the VCM focus motor (address 0x0c) is not detected anywhere. I only have a single MIPI ribbon cable connected — there’s no separate VCM cable. Is that the problem? Do I need some extra hardware to get the autofocus working, or is there a way to manually focus the fixed lens?
Good news — you don’t need any extra cabling. The B0273 uses a motorized autofocus lens (VCM), and the control signals are sent over the same I2C bus as the camera sensor through that single MIPI ribbon cable. No separate VCM cable is needed.
Also, the fact that you’re not seeing the VCM at address 0x0c on a standard I2C scan is completely expected. The VCM is controlled through the camera sensor driver internally — it’s not an independent I2C device that shows up on bus scans.
The blurry image isn’t a hardware issue. The motorized lens simply hasn’t been initialized to the correct position yet programmatically. Let me walk you through fixing that.
Oh okay, that’s reassuring! So how do I get the lens into focus then? And I noticed the colors look a bit off too — kind of red-tinted and washed out. Is that related?
Yes, that red tint/foggy look is a separate issue and also fixable. Here’s what you’ll need to do:
Step 1 — Initialize the focus motor:
You’ll need to run some Python scripts to move the lens to the correct position. Follow the instructions and examples here:
These scripts will let you sweep through focus positions programmatically until you find the sharpest image.
Step 2 — Apply native ISP tuning to fix the color/contrast:
That red tint you’re seeing is a known issue when using the IMX477 without proper ISP tuning tables. Follow the installation guide here to apply the correct tuning:
https://docs.arducam.com/Nvidia-Jetson-Camera/Application-note/Fix-Red-Tint-with-ISP-Tuning/#imx477
Once you complete both steps, the camera should be properly focused and have accurate colors. Let me know if you run into any issues!
