Hey everyone, I’m working on an autonomous racing drone project and I’m hitting a wall with the Jetvariety AR0234 global shutter camera driver. The product page says the driver only supports the original NVIDIA developer carrier board for the Jetson Orin Nano, but I’m running a custom carrier board — the DSBOARD-ORNXS from Forecr. I need to get this camera working for our computer vision pipeline but I can’t find the driver source files anywhere to adapt the device tree and pinmux for our board. Has anyone managed to get the AR0234 working on a third-party carrier? We’re targeting both JetPack 6.2 and 6.1. Any pointers on where I can find the source would be hugely appreciated.
Hi there — thanks for the detailed post. You’re correct that the AR0234 driver in its current form only supports the original developer carrier board. There’s no out-of-the-box support for third-party carrier boards like the Forecr DSBOARD-ORNXS, which is why you’re having trouble getting it to enumerate on your setup. I’ve taken a look at your use case and put together a patch that should help bridge the gap for custom carrier integration. I’ve sent the patch file to you via private message — please check your messages and grab it from there. Give it a review and let me know your thoughts.
Got it, thanks for sending that over. Quick question before I dive in — has this patch been verified against both JetPack 6.1 and 6.2? Our drone stack has some dependencies that pin us to 6.1 for now but we’re planning to move to 6.2 soon, so I need it working across both. Also, is there anything specific I should watch out for when applying it — I’m guessing the changes are mainly around the device tree bindings and the camera interface plumbing?
The patch hasn’t been fully validated on either JetPack version against your specific carrier board yet, so this will be somewhat exploratory. I’d recommend testing on both 6.2 and 6.1 as you mentioned — start with whichever is easier for you to spin up first. Your guess is right: the bulk of the changes target the device tree and the sensor driver’s interface layer so it can recognize the CSI lanes and I2C bus topology on non-reference boards. A few things to keep an eye on when you apply it: double-check that the I2C bus numbers in the device tree match your Forecr board’s actual routing, verify the CSI lane mapping lines up with your physical connection, and make sure the regulator / reset GPIO references point to pins that actually exist on the DSBOARD-ORNXS. If you hit any specific errors during build or at probe time, post the dmesg snippets here and I’ll help you work through them.
Makes sense, thanks for the heads-up on the I2C bus and GPIO mapping — that’s bitten me before on other sensor bring-ups. I’ll apply the patch against both JetPack branches over the next day or two and report back with what I find. Fingers crossed the CSI lane mapping isn’t too far off between the dev board and the Forecr layout. If I need to tweak the pinmux, do you have any documentation on which pins the AR0234 expects for the strobe / trigger signals? That’s kind of critical for our global shutter sync on the drone.
