MultiCameraAdapter v2.2 from uctronics
Model number of the product(s).
Arducam Multi Camera Adapter Module V2.2 for Raspberry Pi 4 B, 3B+, Pi 3, Pi 2, Model A/B/B+, Work with 5MP OV5647 / 8MP IMX219 / 12MP IMX477 Cameras
raspberry pi v4
Linux raspberrypi 5.15.18-v7l+ #1520 SMP Fri Feb 4 12:01:36 GMT 2022 armv7l GNU/Linux
debian 10.11
to install libcamera:
How to access and program the Pivariety Camera using Command Line, Python, OpenCV, and GStreamer
to make libcamera work and detect IMX477:
raspbian - libcamera stack does not work with Bullseye - Raspberry Pi Stack Exchange
camera_auto_detect=0
dtoverlay=imx477,media-controller=0
gpu_mem=256
dtoverlay=vc4-kms-v3d
to get started with the multi-camera adapter v2.2:
https://www.arducam.com/docs/cameras-for-raspberry-pi/multi-camera-adapter-board/multi-camera-adapter-board-v2-1/
Problems you were having.
The multi-camera adapter only detects one of the attached cameras. when I run the c++ and python assemblies. It looks like 12c does not fully work.
pi@raspberrypi:~ $ i2cdetect -y 1
00: – – – – – – – – – – – – –
70: – – – – – – – –
The dmesg log from your hardware.
pi@raspberrypi:~ $ dmesg
[ 0.000000] Linux version 5.15.18-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1520 SMP Fri Feb 4 12:01:36 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 964928
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:5D:BB:A8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3418620K/3866624K available (10240K kernel code, 1389K rwdata, 3288K rodata, 2048K init, 591K bss, 120324K reserved, 327680K cma-reserved, 3080192K highmem)
[ 0.000000] ftrace: allocating 35334 entries in 104 pages
[ 0.000000] ftrace: allocated 104 pages with 3 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[ 0.000000] random: get_random_bytes called from start_kernel+0x574/0x75c with crng_init=1
[ 0.000002] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000024] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000087] bcm2835: system timer (irq = 26)
[ 0.000772] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000794] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000814] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000832] Switching to timer-based delay loop, resolution 18ns
[ 0.001122] Console: colour dummy device 80x30
[ 0.001193] printk: console [tty1] enabled
[ 0.001262] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001293] pid_max: default: 32768 minimum: 301
[ 0.001435] LSM: Security Framework initializing
[ 0.001607] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001636] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003251] cgroup: Disabling memory control group subsystem
[ 0.003497] CPU: Testing write buffer coherency: ok
[ 0.004008] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005269] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005471] rcu: Hierarchical SRCU implementation.
[ 0.006426] smp: Bringing up secondary CPUs …
[ 0.007655] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009004] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010341] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010502] smp: Brought up 1 node, 4 CPUs
[ 0.010527] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010548] CPU: All CPU(s) started in HYP mode.
[ 0.010561] CPU: Virtualization extensions available.
[ 0.011449] devtmpfs: initialized
[ 0.027073] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.027304] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027341] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.037787] pinctrl core: initialized pinctrl subsystem
[ 0.039126] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.043778] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.044604] audit: initializing netlink subsys (disabled)
[ 0.044870] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.045499] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.046300] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.046320] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.046758] Serial: AMBA PL011 UART driver
[ 0.063675] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.110908] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-02-04T12:05:40, variant start
[ 0.120925] raspberrypi-firmware soc:firmware: Firmware hash is a26faf97e3bf76bcc23949d7cdab2f96f399a0c3
[ 0.180863] Kprobes globally optimized
[ 0.186816] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.191662] vgaarb: loaded
[ 0.192162] SCSI subsystem initialized
[ 0.192387] usbcore: registered new interface driver usbfs
[ 0.192478] usbcore: registered new interface driver hub
[ 0.192554] usbcore: registered new device driver usb
[ 0.192997] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.193477] pps_core: LinuxPPS API ver. 1 registered
[ 0.193492] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.193532] PTP clock support registered
[ 0.195298] clocksource: Switched to clocksource arch_sys_counter
[ 0.316078] VFS: Disk quotas dquot_6.6.0
[ 0.316189] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.316375] FS-Cache: Loaded
[ 0.316601] CacheFiles: Loaded
[ 0.317767] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 0.317790] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.318331] Console: switching to colour frame buffer device 240x67
[ 0.328972] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 0.339478] NET: Registered PF_INET protocol family
[ 0.339739] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.341379] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.341413] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.341479] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.341560] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.341729] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.341780] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.342027] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.346267] RPC: Registered named UNIX socket transport module.
[ 0.346285] RPC: Registered udp transport module.
[ 0.346299] RPC: Registered tcp transport module.
[ 0.346313] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.346334] PCI: CLS 0 bytes, default 64
[ 1.146507] Initialise system trusted keyrings
[ 1.146790] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.155879] zbud: loaded
[ 1.157844] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.158714] NFS: Registering the id_resolver key type
[ 1.158765] Key type id_resolver registered
[ 1.158781] Key type id_legacy registered
[ 1.158943] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.158960] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.160081] Key type asymmetric registered
[ 1.160099] Asymmetric key parser ‘x509’ registered
[ 1.160331] bounce: pool size: 64 pages
[ 1.160395] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.160639] io scheduler mq-deadline registered
[ 1.160656] io scheduler kyber registered
[ 1.170274] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.170316] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.170409] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.170513] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00ffffffff → 0x0400000000
[ 1.227413] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.227819] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.227840] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.227861] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.227955] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.228209] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.232035] PCI: bus0: Fast back to back transfers disabled
[ 1.232387] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.232517] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.232949] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.236786] PCI: bus1: Fast back to back transfers disabled
[ 1.236849] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.236877] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.236964] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.236990] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.237408] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.237631] pcieport 0000:00:00.0: PME: Signaling with IRQ 84
[ 1.249394] iproc-rng200 fe104000.rng: hwrng registered
[ 1.249798] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.251490] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.264779] brd: module loaded
[ 1.275526] loop: module loaded
[ 1.276444] Loading iSCSI transport class v2.0-870.
[ 1.281854] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.375451] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.376715] usbcore: registered new interface driver r8152
[ 1.376806] usbcore: registered new interface driver lan78xx
[ 1.376867] usbcore: registered new interface driver smsc95xx
[ 1.428759] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.428802] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.434434] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00001c0000000890
[ 1.435850] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.435874] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.435894] usb usb1: Product: xHCI Host Controller
[ 1.435912] usb usb1: Manufacturer: Linux 5.15.18-v7l+ xhci-hcd
[ 1.435928] usb usb1: SerialNumber: 0000:01:00.0
[ 1.436723] hub 1-0:1.0: USB hub found
[ 1.436823] hub 1-0:1.0: 1 port detected
[ 1.437501] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.437530] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.437555] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.438034] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.438056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.438075] usb usb2: Product: xHCI Host Controller
[ 1.438091] usb usb2: Manufacturer: Linux 5.15.18-v7l+ xhci-hcd
[ 1.438107] usb usb2: SerialNumber: 0000:01:00.0
[ 1.438829] hub 2-0:1.0: USB hub found
[ 1.438899] hub 2-0:1.0: 4 ports detected
[ 1.440803] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.441215] dwc_otg: FIQ enabled
[ 1.441229] dwc_otg: NAK holdoff enabled
[ 1.441243] dwc_otg: FIQ split-transaction FSM enabled
[ 1.441260] Module dwc_common_port init
[ 1.441757] usbcore: registered new interface driver uas
[ 1.441884] usbcore: registered new interface driver usb-storage
[ 1.442097] mousedev: PS/2 mouse device common for all mice
[ 1.447554] sdhci: Secure Digital Host Controller Interface driver
[ 1.447571] sdhci: Copyright(c) Pierre Ossman
[ 1.448406] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.452445] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.452787] hid: raw HID events driver (C) Jiri Kosina
[ 1.452991] usbcore: registered new interface driver usbhid
[ 1.453007] usbhid: USB HID core driver
[ 1.459733] Initializing XFRM netlink socket
[ 1.459780] NET: Registered PF_PACKET protocol family
[ 1.459900] Key type dns_resolver registered
[ 1.460377] Registering SWP/SWPB emulation handler
[ 1.461207] registered taskstats version 1
[ 1.461239] Loading compiled-in X.509 certificates
[ 1.462102] Key type ._fscrypt registered
[ 1.462120] Key type .fscrypt registered
[ 1.462134] Key type fscrypt-provisioning registered
[ 1.474875] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.475199] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.475386] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 38, base_baud = 0) is a PL011 rev2
[ 1.484901] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.485466] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.486742] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.486763] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.516014] of_cfs_init
[ 1.516270] of_cfs_init: OK
[ 1.551748] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.552307] Waiting for root device /dev/mmcblk0p7…
[ 1.605882] mmc1: new high speed SDIO card at address 0001
[ 1.648503] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.649537] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 1.654450] mmcblk0: p1 p2 < p5 p6 p7 >
[ 1.655718] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 1.676897] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.676993] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 1.682484] devtmpfs: mounted
[ 1.693987] Freeing unused kernel image (initmem) memory: 2048K
[ 1.725353] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.735633] Run /sbin/init as init process
[ 1.735649] with arguments:
[ 1.735663] /sbin/init
[ 1.735676] splash
[ 1.735689] with environment:
[ 1.735701] HOME=/
[ 1.735714] TERM=linux
[ 1.908043] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.908073] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.908092] usb 1-1: Product: USB2.0 Hub
[ 1.910505] hub 1-1:1.0: USB hub found
[ 1.910789] hub 1-1:1.0: 4 ports detected
[ 2.113171] systemd[1]: System time before build time, advancing clock.
[ 2.208074] NET: Registered PF_INET6 protocol family
[ 2.209893] Segment Routing with IPv6
[ 2.209938] In-situ OAM (IOAM) with IPv6
[ 2.285399] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.286647] systemd[1]: Detected architecture arm.
[ 2.327187] systemd[1]: Set hostname to .
[ 2.868883] systemd[1]: /etc/systemd/system/teamviewerd.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
[ 3.112341] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.122208] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.122954] systemd[1]: Listening on udev Control Socket.
[ 3.123445] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.126936] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.128233] systemd[1]: Created slice system-getty.slice.
[ 3.128912] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.129070] systemd[1]: Reached target Swap.
[ 3.129592] systemd[1]: Listening on udev Kernel Socket.
[ 3.290845] i2c_dev: i2c /dev entries driver
[ 3.592894] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null). Quota mode: none.
[ 3.725498] systemd-journald[121]: Received request to flush runtime journal from PID 1
[ 4.454345] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.455011] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.455929] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.458530] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.719232] mc: Linux media interface: v0.10
[ 4.758713] videodev: Linux video capture interface: v2.00
[ 4.794875] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.798407] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.798445] [vc_sm_connected_init]: start
[ 4.799341] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.800367] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.803957] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.804315] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.821428] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 4.822688] [vc_sm_connected_init]: installed successfully
[ 4.825838] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.828350] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.843142] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.846735] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.856932] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.858433] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.859033] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.859520] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.859862] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.859894] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.859920] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.859944] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.859967] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.872420] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 4.873249] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 4.874138] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 4.874691] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 4.874729] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.874771] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.874808] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.874831] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.875033] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.896908] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.896965] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.972080] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.972176] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.978971] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.979048] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.982169] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 4.982216] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.069825] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.070618] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.071462] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 5.071864] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.083411] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.398570] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.404418] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[ 5.404451] fb0: switching to vc4 from simple
[ 5.464850] Console: switching to colour dummy device 80x30
[ 5.481019] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.502773] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.555089] Registered IR keymap rc-cec
[ 5.555338] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.555609] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 5.565672] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 5.567250] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.600077] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.601981] usbcore: registered new interface driver brcmfmac
[ 5.603298] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 5.708956] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.710776] Registered IR keymap rc-cec
[ 5.750354] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.750964] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 5.889885] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.890010] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.899784] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 6.315128] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.327990] Registered IR keymap rc-cec
[ 6.328183] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.328420] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 6.338291] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.354270] Registered IR keymap rc-cec
[ 6.354523] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 6.354893] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input3
[ 6.362102] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 6.362677] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 6.363136] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.363585] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.363989] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.364316] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.364788] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 6.385101] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 6.454106] Console: switching to colour frame buffer device 240x67
[ 6.454171] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.066188] imx477 10-001a: Device found is imx477
[ 7.066795] imx477 10-001a: Consider updating driver imx477 to match on endpoints
[ 8.009999] random: crng init done
[ 8.010031] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.054441] 8021q: 802.1Q VLAN Support v1.8
[ 8.104258] uart-pl011 fe201000.serial: no DMA platform data
[ 8.547852] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.639137] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.155999] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.156644] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.814372] broken atomic modeset userspace detected, disabling atomic
[ 13.782660] fuse: init (API version 7.34)
[ 14.030388] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.977222] Bluetooth: Core ver 2.22
[ 14.977282] NET: Registered PF_BLUETOOTH protocol family
[ 14.977289] Bluetooth: HCI device and connection manager initialized
[ 14.977304] Bluetooth: HCI socket layer initialized
[ 14.977313] Bluetooth: L2CAP socket layer initialized
[ 14.977329] Bluetooth: SCO socket layer initialized
[ 14.999679] Bluetooth: HCI UART driver ver 2.3
[ 14.999694] Bluetooth: HCI UART protocol H4 registered
[ 14.999748] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.999927] Bluetooth: HCI UART protocol Broadcom registered
[ 15.359963] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.359977] Bluetooth: BNEP filters: protocol multicast
[ 15.359990] Bluetooth: BNEP socket layer initialized
[ 15.397616] Bluetooth: RFCOMM TTY layer initialized
[ 15.397645] Bluetooth: RFCOMM socket layer initialized
[ 15.397665] Bluetooth: RFCOMM ver 1.11
[ 16.000719] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 31.835321] cam-dummy-reg: disabling
[ 31.835339] cam1-reg: disabling
[ 55.251443] v3d fec00000.v3d: MMU error from client L2T (0) at 0x5041000, pte invalid
Troubleshooting attempts you’ve made:
enabling and disabling and enabling configs.
Make 12c work and detect all cameras. Please note that one camera is being detected while connected to the adapter, but the other 3 are not detected by the arducam codes.
