I am developping a system that need 4 images taken almost simultaneously. So, I bought your multicam adapter v2.1.
I have developped the following program using python+opencv, based on your code example (4cam_cv3.py)
openthecamera device (cam = cv2.VideoCapture(0) )
configure the 4 cams (gpio+i2c+ resolution/exposure config)
do 300 times
do 4 times
select the cam (gpio...)
read cam image (in order to empty the opencv cam buffer , )
read cam image (in order to empty the opencv cam buffer)
read cam image ( ret, frame = cam.read() )
write cam image on file
Unfortunately I am getting a lot of faulty images : in some image I am getting a set of multicolored lines + half & top bottom of these images are swapped).
Since the camera are not synchronized I guess that swapping the mipi signal in the middle of an image transfer generate this kind of problem (i.e. synchronization issue).
Slowing down everything seems to reduce the number of faulties image but it is then too slow for our application.
The Multi_Camera_Adapter_V2.1/4cam_cv3.py display correctly the 4 images in fast sequence, I see no faulty image but I think that faulty images happend but are quicly hidden by new images coming.
Can you please help me (we are working on a real industrial project so if it works correctly we will need a lot of your boards)
At present, our hardware does not support synchronize capture due to the clock is out of sync.
So you can’t get each camera’s image. Because we can’t ensure after the first camera capture done, we are not sure the second camera is beginning capture.
