https://ca.robotshop.com//products/arducam-multi-camera-adapter-module-v22-raspberry-pi
And 4 of Raspberry Pi Camera Module V2 from Digikey (cannot attach link due to new user limitation) -
For the adapter: B012001
For the cameras: 913-2664 -
Raspberry Pi + Multi Cam Adapter + 4 of Raspberry Pi Camera Module V2 -
Attached instruction, which is the same as in https://www.uctronics.com/download/Amazon/B0120.pdf -
Camera is detected using the vcgencmd, but I cannot run the init.sh file that you guys have on the git. The Rpi also works for a single camera (without the multi cam adapter). When multi cam adapter plugged in I can see the LED light on the multi cam.
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python $ sudo ./init_camera.sh
----Test i2c1
00: β β β β β β β β
10: β β β β β β β β β β β β β β β β
20: β β β β β β β β β β β β β β β β
30: β β β β β β β β β β β β β β β β
40: β β β β β β β β β β β β β β β β
50: β β β β β β β β β β β β β β β β
60: β β β β β β β β β β β β β β β β
70: 70 β β β β β β β
----Detecting the /dev/video0 device
video0 detected!
βStart testing each camera
if all of them are normal, after it finished,you will see four image in the current path.
Start testing the camera A
Made X/EGL preview window
[0:10:05.832189663] [1409] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3866-0c55e522
Start testing the camera B
[0:10:06.961498310] [1426] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3866-0c55e522
Start testing the camera C
[0:10:08.191336129] [1457] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3866-0c55e522
Start testing the camera D
[0:10:09.357711297] [1481] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3866-0c55e522
[email protected]:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python $ vcgencmd get_camera
supported=1 detected=1, libcamera interfaces=0
sudo dmesg | grep arducam -----> Does not return anything -
Troubleshooting attempts youβve made?
I double checked the hardware configuration and it looks the same as in the manual's pic. The cables are in the right direction. I have tried to update the Rpi to the latest version and other different things, but no success. -
I think it is a software issue? But I am new to Rpi so I am struggling a bit. Any help is appreciated, thanks!
