Hi, I was following step by step on github. Up to step " sudo ./init_camera.sh" , it shows that " Cant find video0 device…". I try to follow your suggestion at the bottle of github page but I could not get it right. I wonder what is the command line to “add dtparam=i2c_vc=on to /boot/config.txt”
I try to build a 360 degree bird view on your multi-adapter-board- 4 channels for my RC car. If you have someone who can help me with troubleshoot that would be awesom
While the 4 cameras multi_adapter _ board connected on the Raspberry Pi, I wondered if it is still possible to get access to the 4 video data from raspberry pi via MATLAB Support Package for Raspberry Pi Hardware.
For 4-1 stereo hat, different cameras have different frame rates with different resolutions. We tested the OV9281 4-in-1 resolution of 1280*4 x 800, which can reach 30fps on the Raspberry Pi and 45fps on the jetson Nano.
I have a v2.2 and I was able to get 2 cameras working with the C++ previewOpencv executable. However, I cannot get the python scripts working. Could you send me the documentation to run the previewOpencv.py please?
It need to modify the python demo. I will help you write a demo for two cameras and reply you as soon as possible. Or you can refer to our 4 camera demo to modify.
I have optimized the script and support the customization of the number of cameras.
If you have two cameras, just define the cmNum=2 which is in the Multi_Camera_Adapter/Multi_Adapter_Board_4Channel/Multi_Camera_Adapter_V2.2_python/AdapterBoard.py file. Then connect the camera to the A and B port
I have a Arducam Multi Camera Adapter module v2.2 using with Raspberry pi 4B with Python 2.7.16 version, OpenCV 4.5.0 and Numpy 1.16.2. I followed the documentation online and tutorial video. However, I need the python script because I have other things to control with the raspberry pi, but I cannot get the python scripts to work.I did enable the raspi-config for I2C and camera, and also add (dtparam=i2c_vc=on) to the end line in sudo nano /boot/config.txt. I tested the sudo chmod +x init_camera.sh line for the files in the python folder and also tested AdapterTestDemo.py code working good but I can’t run and got error in PreviewOpencv.py programming .
I have a v2.2 and I was able to get 4 cameras working with the C++ previewOpencv executable. However, I cannot get the python scripts working. Actually I want capture image using 4 camera when press key. Could you send me the documentation to run the previewOpencv.py please?
Thank you so much, now working for me when I changed camera = cv.VideoCapture(0) to camera = cv.VideoCapture(-1) because I using Picamera.
Is that possible that we can use 4 Arducam 8MP Pan Tilt Zoom PTZ Camera with Arducam multi camera adapter for auto zoom each of camera using single Raspberry Pi 4 B+ or we can create a code specific(I2C) for adjust zoom and focus using arduino microcontroller.
I think if you use external power, maybe it will be OK. I think it is a great idea to use arduino microcontroller, which can driver the PTZ lens and the pi just receive image and display.
Thank you for your guidance and support bin. I keep on trying in programming for adjust PTZ lens but still errors. Can i get any references code for adjust PTZ lens?
