Motion trails at max resolution 5120x800 with Arducam OV9281 global shutter on Raspberry Pi
Hi all, I’m having a motion-trail problem with my Arducam 1MP*4 Quadrascopic OV9281 Global Shutter setup and I’m kind of stuck.
When I capture a luminous bar moving at roughly 1 m/s, I get a trail in the direction of the light bar. The weird part is it shows up even with the shutter at 10 microseconds, and increasing or decreasing the shutter doesn’t change it.
It only happens in the max resolution mode (5120:800). At 2560:800 I don’t see any trails. Also, the 5120 images come out noticeably brighter than 2560 with the same shutter value. The trail appears on all four cameras, and the fastest I can go in 5120 mode feels limited.
My setup:
  • Arducam 1MP*4 Quadrascopic OV9281 Global Shutter Monochrome Camera Bundle Kit
  • Raspberry Pi 4B and Pi 5 (8 GB RAM)
  • working distance: 1.5 m
  • lenses: 25 mm
  • sensor size: 0.003 mm/pp
  • object speed: ~1 m/s
I was expecting to be able to do static captures of objects up to about 18 m/s.
Commands I’ve tried:
rpicam-still --shutter 10 --gain 1.0 --contrast 1.5 --mode 5120:800:R8 -o image%04d.jpg -n --timeout 30000 --timelapse 2000
rpicam-raw --shutter 10 -t 5000 --contrast 2.0 --framerate 20 --mode 5120:800:8:U --gain 1 --output /var/tmp/video0.raw
rpicam-still --shutter 2000 --contrast 1.0 --brightness 0.0 --gain 0.0 --saturation 0.0 --mode 5120:800:8 --output imagen_r8.jpg
Things I’ve already swapped/tested: connection cables, the Quadrascopic Hat, the cameras themselves, rpicam-still vs rpicam-raw, Raspberry Pi 4 vs Pi 5, and Bullseye vs Bookworm. Install followed the Arducam Pivariety Camera Quick Start Guide.
Has anyone seen this before?
Thanks for the detailed write-up. Let me make sure I’ve got it right: the trail follows the direction of the moving light bar, appears on all four cameras, only happens at 5120:800, and doesn’t go away even at a 10 us shutter. Given everything you’ve already swapped, that rules out a lot of the usual suspects.
Before I dig deeper, could you upload a few sample images or a short video showing the trail? Seeing the actual captures will help a lot in narrowing this down.
Sure, here are some captures. The object is a luminous bar with a 50 mm radius placed 1.5 m from the cameras, moved by hand at about 1 m/s. The trail is visible in all four cameras:
Thanks for the photos — I can see the trail in all four frames.
One thing I noticed in your raw command:
You set the framerate to 20 fps. Did you try increasing it to something like 30 fps? At 5120x800 the readout/transfer pipeline is under more load, so I want to rule out framerate contributing to the trail.
Yes, I already tried 30 fps, 20 fps and 5 fps. The trail is still there in all cases.
Good to know. I grabbed a sample unit from our warehouse to reproduce this on our side.
I pointed the camera at an incandescent light and moved it around quickly while previewing with:
libcamera-still -t 0
In the live preview stream I couldn’t see any motion blur at all. The blur/trail only appears once images are saved, so it seems tied to the capture path rather than the sensor streaming itself. That matches your observation — the stream looks clean, but the saved captures show the trail.
That’s a useful clue. I checked the logs and noticed the preview is processed at 2560x400-YUV420, but the capture is done at 5120x800-YUV420. So the two paths are using different modes.
Preview log:
[0:27:15.065920857] [3793] INFO Camera camera.cpp:1028 configuring streams: (0) 2560x400-YUV420
Capture log:
[0:27:20.470038947] [3801] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/i2c@1/arducam_pivariety@c - Selected sensor format: 5120x800-Y10_1X10 - Selected unicam format: 5120x800-Y10P
On another OV9281 setup I used before, I was able to capture a moving light bar at low exposure without this problem. So is it actually possible to capture a full 5120x800 image of a moving light bar without the trail using the Arducam Quadrascopic Pi Hat?
Just checking in — any update on this? Same observations as before: preview stream at 2560x400-YUV420, capture stream at 5120x800-YUV420, and sensor/unicam formats 5120x800-Y10_1X10 / 5120x800-Y10P.
Thanks for your patience. Based on the logs and our testing, here’s where this lands:
At 5120x800, the sensor’s readout speed and the data transfer rates on the Quadrascopic Hat create inherent motion blur when the object is moving. So the trail at full resolution isn’t a software bug — it’s a limitation of the current hardware in that mode. That’s also why you don’t see it at 2560x800.
For fast-moving light bars, the practical workaround is to capture at a lower resolution and/or adjust the exposure settings. That should give you much cleaner motion captures within what the hardware can do.
Understood, thanks. For my use case I need four synchronized cameras with at least 1 MP resolution each. Can Arducam suggest a suitable option that would handle this?
To wrap up the original issue: the trail at 5120x800 is a hardware limitation (sensor readout speed and data transfer on the Quadrascopic Hat), not a software defect, and the workaround is lower resolution capture and/or exposure adjustment. For the four synchronized 1 MP+ camera requirement, let me check what options fit those specs and I’ll get back to you.
