Missing AR1335 config file for Arducam USB2 Camera Shield on Jetson Nano
Hi, I’m trying to get an AR1335 camera working with the Arducam USB2 Camera Shield on a Jetson Nano and I’m stuck. The camera is the 13MP MIPI Camera Module with AR1335 OBISP and M12 mount lens (model B0277). The shield is connected and I’ve got the demo software installed, but I can’t find the config file that the camera shield needs for this camera. Can someone point me to the right config file, or walk me through the setup? Thanks.
Hi, for the USB2 Camera Shield on Jetson Nano the best starting point is the Python demo repo here: GitHub - ArduCAM/ArduCAM_USB_Camera_Shield_Python_Demo · GitHub — it has the library plus the sample scripts. Have a look through it and let me know if you still can’t find what you need.
Thanks, I went through that repo but I’m still not seeing a config file for the AR1335. Is there not an AR1335 specific config file? Is there an alternative config file I should be using? I basically need the config for this camera + shield combo so I can initialize it on the Jetson Nano.
Let me make sure I understand the setup — which config files are you actually seeing right now? The shield normally loads a per-sensor config (register settings in a .cfg/.txt style file) when the camera initializes. What path are you looking in, and what files are present there? That’ll tell us whether it’s a missing file or something else.
I’m looking in the config folder in the demo repo. I see entries for a bunch of other sensors but nothing that says AR1335. That’s the part I don’t get — I’d expect the config to be named after the sensor. Should I be using one of the other configs as a fallback, or is there a separate file somewhere else I haven’t found?
Sorry for the confusion here — I ignored the detail in your last message, that’s on me. I checked with our chief engineer and the camera you bought can’t work with the USB 2.0 camera shield. That’s the reason there’s no AR1335 config for it: it’s a compatibility issue, not a missing file, so there’s nothing you can load that will make it work on the shield. Apologies for the misleading info earlier. If you tell me what you’re ultimately trying to build, I can point you at a camera + shield combination that is actually supported.
Alright, thank you for your help. Appreciate you checking with the engineer.
Just to close this out for anyone reading: the AR1335 module (B0277) is a MIPI camera for Raspberry Pi/Jetson, and it isn’t compatible with the USB2 Camera Shield — so there is no config file that will make it enumerate, and there’s no workaround on the shield side. If you need a shield-based setup, the sensor has to be one of the supported ones for that shield. If anything else comes up, post back here.
