Measurement from the tof camera
How does the Arducam ToF camera reports depths?
  1. from the center of the lens to each location of the target
  2. Or each points location in the target is projected on a virtual plane passing through the sensor plane
Thank you very much
In the SDK, the reported depth values are based on a virtual image plane that is parallel to the object. This image plane represents the projection of the scene as seen through the lens of the camera. Essentially, the SDK provides the depth from the object to this image plane, not directly from the sensor to the object.
Hi @Dion Thank you so much for very helpful information
Hi @Dion ,
Thanks for the clarification but then could you please explain why we find that the depth measured from the ToF to a straight object appears curved? Your forum doesn’t seem to accept uploading images so I have posted the follow-up on github. Kindly please have a look over their at github.
