Sertronics (Berrybase)
Arducam Multi Camera Adapter V 2.2 (UC-475 Rev. C) and two Raspberry Pi High Quality Camera (IMX477 Sensor) conected to ports A and C of the adapter board
Raspberry Pi 4 Model B; OS: Raspbian GNU/Linux 10 (buster)
I adapted the C++ source code provided here:
- Problems you were having?
I tried to capture still images from my two cameras. Everythings works finde as long as my selected resolution does not exceed 1280 x 720 pixels. Higher resolutions cause a message “select timeout” after camera initialization and no images are captured. Is this intended behaviour, or is this probably a driver issue?
I have tested one of the cameras by connecting it directly to the Pi to check if it is a camera issue. I was able to capture images with full resolution. However, with two cameras connected to the Pi via the Multi Camera Adapter Board, I was not able to capture images with resolutions exceeding 720p.
- What help do you need?
Information on how to increase the resolution when capturing images from two cameras using the Multi Camera Adapter Board.
