Max cable length for Arducam lens board camera on Pi 4? 1m cable intermittent
Hi, hoping someone can help. I’m using one of the Raspberry Pi lens board cameras (model B013JTY8WY) on a Raspberry Pi 4 Model B (4GB). The short 15 cm cable works reliably, but as soon as I try a longer 1 m cable the camera becomes intermittent — it’ll work for a while, then drop out. I’ve already tried swapping in and out other cameras and cables to rule those out, and the behavior follows the cable. I can’t find anything about this in the online docs. What is the maximum cable length possible with the lens board camera? There’s no max cable length listed anywhere in the documentation, so that’s really the question I need answered.
Thanks for the details. For extending the camera connection there are basically three solutions you can use:
  1. CSI to HDMI cable extension module with 15pin 80mm FPC cable for Raspberry Pi camera — Arducam MIPI CSI 2 to HDMI Converter Board & Extension Cables
  2. 300mm extension cable for Raspberry Pi / Jetson Nano V2 camera module — https://www.uctronics.com/arducam-300mm-extension-cable-for-raspberry-pi-jetson-nano-v2-camera-module.html
  3. 15-meter cable extension kit — 10-Meter Cable Extension Kit
Have a look at the links to check whether the available products suit your need. If not, contact [email protected] for more help.
Appreciate the reply, but I still don’t see an answer to my actual question. I get that there are extension products, but what I need to know is the maximum cable length possible with the lens board camera. Right now 15 cm works and 1 m is intermittent. Is there a documented max? The three links don’t state a maximum length for this specific camera either, so I’m still stuck on the same thing.
Fair point — let me answer it directly. The lens board camera doesn’t have a single published “max length” figure, and that’s part of the problem. With the standard 15-pin FPC (that thin flat ribbon), the reliable length is quite short; the ~15 cm cable is what’s designed to work consistently. Once you push out to ~1 m with a plain FPC ribbon you’re at or past the limit for that signal on this camera, which is why you get intermittent behavior instead of a clean failure — it’s marginal signal integrity, not a dead camera.
So the short answer: the max length with the flat ribbon on this camera is effectively the short (~15 cm) cable. For anything beyond a short run you can’t just use a longer FPC — you need one of the three extension approaches:
  • a CSI-to-HDMI extension module (converts to HDMI so you can run much longer)
  • the 300mm extension cable
  • the 15-meter cable extension kit (which enables genuinely long runs)
If none of those fit your requirement, contact [email protected].
That’s more like it — so there’s no longer FPC ribbon option, it’s the short cable or move to one of the extension kits. Two follow-ups:
  1. Does the 300 mm extension cable actually get me past the 15 cm reliably, or is it still in the marginal zone?
  2. Anything I should watch out for with the 15-meter kit on a Pi 4, or is it basically plug and play?
For what it’s worth, while the 1 m cable is in a dropout the camera stops being detected (vcgencmd get_camera shows nothing), and it comes back when I re-seat or switch back to the 15 cm cable. I didn’t capture logs since it’s intermittent, but wanted to mention it in case it helps pin down the cause.
Good observations — the camera dropping out of vcgencmd get_camera on a long ribbon and recovering on the short one is classic for a marginal cable run rather than a faulty camera, so you’re reading it right.
On your questions:
  1. The 300 mm cable is an extension cable made for the Pi / Jetson Nano V2 camera module. It’s not a plain long ribbon, so it’s intended to work at that length as long as it’s fully seated and your camera/module revision matches what the product page supports. Think of it as the “supported” range rather than the marginal zone the 1 m ribbon puts you in.
  2. The 15 m kit is the option for a genuinely long run — it uses a different signalling approach, not a straight ribbon, which is how it manages that distance.
One caveat: these extension options are built around particular camera/module families, so always double-check the specific product page against your camera revision before buying. If none of the three suits your setup, contact [email protected] with your Pi model, camera model and required distance and they can advise.
OK, I’ll go through the product pages against my camera revision. Sounds like I should treat the 15 cm as the reliable baseline and pick whichever extension kit matches the distance I need. Just to close the loop on the original question — there’s no listed maximum length for the lens board camera itself, the practical limit is basically the short cable, and anything longer means one of the three extension solutions. If that’s right I’ll go that route. Thanks for sticking with it.
Yes, that’s exactly it. Quick summary of where we landed:
  • The lens board camera doesn’t tolerate long plain FPC ribbon cables — the short (~15 cm) cable is the reliable baseline, and ~1 m ribbons give intermittent behavior (marginal signal, not a dead camera).
  • There is no single documented “max length” number for this camera; the practical answer is that the short cable is the limit for a straight ribbon, and anything longer needs an extension solution.
  • The three options are the CSI-to-HDMI extension module, the 300mm extension cable, and the 15-meter cable extension kit, depending on how far you need to go.
  • Check each product page against your camera revision; if none fit your requirement, contact [email protected] with your setup details.
Post back and let us know which route you go with, or if anything still looks off.
