Been banging my head against this for a couple days now. I’ve got the Arducam 1MP*4 Quadrascopic Camera Bundle Kit (SKU: B0331) hooked up to an NVIDIA Jetson Nano, and I’m using the example OpenCV code to pull data from all 4 cameras. Problem is, I’m maxing out at around 2.7 fps. That’s gotta be wrong for this setup.
I also tried switching to just a single channel to see if the frame rate would improve, but something weird is going on — there’s a register issue that’s blocking me from changing the channel setting at all.
Here’s what dmesg spits out when I filter for arducam:
Your dmesg output tells a pretty clear story actually. Look at what’s happening with the two I2C addresses:
7-000c: probes fine, firmware 0x10004, sensor ID 0x9281, gets registered and bound to the VI
8-000c: fails hard — “Reading register 0x103 failed” followed by “probe failed” and “Failed to setup board”
So only one sensor interface is actually coming up. That register 0x103 read failure on 8-000c is the smoking gun here. It means the driver can’t communicate with the second camera over the I2C/CAM bus, so the multi-camera setup never initializes properly.
If only one out of four cameras is operational, ~2.7 fps starts making sense — you’re basically getting single-camera throughput but spread across the attempted multicamera pipeline.
What else have you tried so far? Did you run any of the other example scripts or just the OpenCV one?
Pretty much just the OpenCV example that reads all 4 cameras — that’s where I measured the 2.7 fps. After seeing that, I poked around trying to force it to use only one channel, but the register write to change the channel just won’t take. Feels like whatever is broken at the driver level is also blocking the channel switching.
For reference this is the standard Arducam 1MP*4 Quadrascopic bundle (B0331) on a Jetson Nano, nothing exotic about the setup.
Right, that channel selection being blocked makes total sense in this context. If the second camera interface at 8-000c never completed its probe, the driver’s internal state is probably not set up correctly to handle channel switching — it thinks it only has one camera to manage.
To recap what we’re looking at:
Firmware: 0x10004
Sensor ID: 0x9281
Only 7-000c is bound and operational
8-000c probe fails on register 0x103 read
This could be a few things: a physical connection issue with the second camera interface, an I2C address conflict, or a driver/firmware mismatch that prevents the multi-camera initialization from completing. The register 0x103 failure is the root of it all.
Next thing I’d try — can you run v4l2-ctl against the device that did register and see what framerates it’s actually advertising? That’ll give us a baseline for what the single working sensor is capable of. Something like:
