Looking for Arducam UC-573 I2C spec to control focus/zoom from Arduino
Hi, I’ve got a UC-573 board that I’m using with Arduino. I’ve been trying to find the I2C driver/interface specification for the board, but I can’t seem to locate it anywhere. Can someone share a link to the I2C interface spec for the ARDUCAM UC-573?
Can you tell me exactly which camera module you’re using with it? There are several Arducam products that use the same UC-573 board, so I need to pin down the exact module before I can point you to the right spec. Do you have the model number or the product page it was sold under?
I actually don’t have a camera module at all. When I bought it, it was just the UC-573 board by itself. That’s why I’m trying to find the I2C spec for the board specifically. My plan is to put this board on any Arducam camera board and control focus and zoom over I2C. I can send a picture of the board if that helps.
That does make it harder, because the UC-573 board is shared across multiple Arducam products, so the I2C register map isn’t necessarily the same for every camera it gets paired with. A picture of the board would definitely help. Could you send one through private message? I’ll check the board markings and revision to try to match it to the right product family.
Sure, I’ll send a photo privately. Just to be clear, there’s no camera module attached — only the bare UC-573 board. I need to be able to drive focus and zoom once it’s mounted onto an Arducam camera board.
Thanks, please send it over when you can. Right now the main blocker is product identification: because the same UC-573 board is used in several different Arducam cameras, the I2C spec can differ depending on which camera module it belongs with. Once I see the photo and identify the board revision, I should be able to point you to the correct I2C interface documentation for focus/zoom control.
