Loading configuration file failed
windell@windell-ThinkPad-T490:~/PycharmProjects/arducam_code/ArduCAM_USB_Camera_Shield_Python_Demo$ python3 ArduCam_Demo.py -v --preview-width 1280 -f AR0135_MONO_8b_1280x964_30fps.cfg
File “/home/windell/PycharmProjects/arducam_code/ArduCAM_USB_Camera_Shield_Python_Demo/ArduCam_Demo.py”, line 50, in
if not camera.openCamera(config_file):
File “/home/windell/PycharmProjects/arducam_code/ArduCAM_USB_Camera_Shield_Python_Demo/Arducam.py”, line 15, in openCamera
self.isOpened, self.handle, self.cameraCfg, self.color_mode = camera_initFromFile(
File “/home/windell/PycharmProjects/arducam_code/ArduCAM_USB_Camera_Shield_Python_Demo/utils.py”, line 41, in camera_initFromFile
config = arducam_config_parser.LoadConfigFile(fileName)
File “/home/windell/.local/lib/python3.10/site-packages/arducam_config_parser/arducam_config_parser.py”, line 117, in LoadConfigFile
raise RuntimeError(“Loading configuration file {} failed.”.format(name))
RuntimeError: Loading configuration file AR0135_MONO_8b_1280x964_30fps.cfg failed.
Im running Ubuntu Linux and I went through the instructions on dowloading the driver etc. Here is the contents of the directory to verify that the configure file is in the same place as the code.
windell@windell-ThinkPad-T490:~/PycharmProjects/arducam_code/ArduCAM_USB_Camera_Shield_Python_Demo$ ls
AR0135_MONO_8b_1280x964_30fps.cfg ArduCam_Demo.py Arducam.py ImageConvert.py pycache README.md requirements.txt utils.py
Has anyone has the same problem? Does anyone know how to fix this?
@windell747
Have you modified the configuration file? if not please send me the configuration file.
