using this function I war able to write.
Unfortunatelly it tells me “capture timeout.”. Suggestions?
#include "arducam_mipicamera.h"
#include <linux/v4l2-controls.h>
#include <stdio.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
#define LOG(fmt, args...) fprintf(stderr, fmt "\n", ##args)
void save_image(CAMERA_INSTANCE camera_instance, const char *name, int width, int height) {
IMAGE_FORMAT fmt = {IMAGE_ENCODING_RAW_BAYER, 0};
// The actual width and height of the IMAGE_ENCODING_RAW_BAYER format and the IMAGE_ENCODING_I420 format are aligned,
// width 32 bytes aligned, and height 16 byte aligned.
BUFFER *buffer = arducam_capture(camera_instance, &fmt, 6000);
if (!buffer) {
LOG(“capture timeout.”);
return;
if(0){
BUFFER *buffer2 = arducam_unpack_raw10_to_raw8(buffer->data, width, height);
arducam_release_buffer(buffer);
buffer = buffer2;
FILE *file = fopen(name, “wb”);
fwrite(buffer->data, buffer->length, 1, file);
fclose(file);
int main(int argc, char **argv) {
CAMERA_INSTANCE camera_instance;
int width = 2592, height = 1944;
char file_name[100];
LOG(“Open camera…”);
int res = arducam_init_camera(&camera_instance);
if (res) {
LOG(“init camera status = %d”, res);
return -1;
//width =2592;//2336;//4672;//1920;
//height =1944;//1748;//3496;//1080;
LOG(“Setting the resolution…”);
// res = arducam_set_resolution(camera_instance, &width, &height);
res = arducam_set_mode(camera_instance, 0);
if (res) {
LOG(“set resolution status = %d”, res);
return -1;
} else {
// LOG(“Current resolution is %dx%d”, width, height);
LOG(“Notice:You can use the list_format sample program to see the resolution and control supported by the camera.”);
arducam_write_sensor_reg(camera_instance, 0x0103,0x01);
sleep(1);
arducam_write_sensor_reg(camera_instance, 0x3827,0xEC);
arducam_write_sensor_reg(camera_instance, 0x370C,0x03);
arducam_write_sensor_reg(camera_instance, 0x3612,0x5B);
arducam_write_sensor_reg(camera_instance, 0x3618,0x04);
arducam_write_sensor_reg(camera_instance, 0x5000,0x06);
arducam_write_sensor_reg(camera_instance, 0x5002,0x40);
arducam_write_sensor_reg(camera_instance, 0x5003,0x08);
arducam_write_sensor_reg(camera_instance, 0x5A00,0x08);
arducam_write_sensor_reg(camera_instance, 0x3000,0x00);
arducam_write_sensor_reg(camera_instance, 0x3001,0x00);
arducam_write_sensor_reg(camera_instance, 0x3002,0x00);
arducam_write_sensor_reg(camera_instance, 0x3016,0x08);
arducam_write_sensor_reg(camera_instance, 0x3017,0xE0);
arducam_write_sensor_reg(camera_instance, 0x3018,0x44);
arducam_write_sensor_reg(camera_instance, 0x301C,0xF8);
arducam_write_sensor_reg(camera_instance, 0x301D,0xF0);
arducam_write_sensor_reg(camera_instance, 0x3A18,0x00);
arducam_write_sensor_reg(camera_instance, 0x3A19,0xF8);
arducam_write_sensor_reg(camera_instance, 0x3C01,0x80);
arducam_write_sensor_reg(camera_instance, 0x3B07,0x0C);
arducam_write_sensor_reg(camera_instance, 0x380C,0x1F);
arducam_write_sensor_reg(camera_instance, 0x380D,0x1B);
arducam_write_sensor_reg(camera_instance, 0x3814,0x11);
arducam_write_sensor_reg(camera_instance, 0x3815,0x11);
arducam_write_sensor_reg(camera_instance, 0x3708,0x64);
arducam_write_sensor_reg(camera_instance, 0x3709,0x12);
arducam_write_sensor_reg(camera_instance, 0x3808,0x0A);
arducam_write_sensor_reg(camera_instance, 0x3809,0x20);
arducam_write_sensor_reg(camera_instance, 0x380A,0x07);
arducam_write_sensor_reg(camera_instance, 0x380B,0x98);
arducam_write_sensor_reg(camera_instance, 0x3800,0x00);
arducam_write_sensor_reg(camera_instance, 0x3801,0x00);
arducam_write_sensor_reg(camera_instance, 0x3802,0x00);
arducam_write_sensor_reg(camera_instance, 0x3803,0x00);
arducam_write_sensor_reg(camera_instance, 0x3804,0x0A);
arducam_write_sensor_reg(camera_instance, 0x3805,0x3F);
arducam_write_sensor_reg(camera_instance, 0x3806,0x07);
arducam_write_sensor_reg(camera_instance, 0x3807,0xA3);
arducam_write_sensor_reg(camera_instance, 0x3811,0x10);
arducam_write_sensor_reg(camera_instance, 0x3813,0x06);
arducam_write_sensor_reg(camera_instance, 0x3630,0x2E);
arducam_write_sensor_reg(camera_instance, 0x3632,0xE2);
arducam_write_sensor_reg(camera_instance, 0x3633,0x23);
arducam_write_sensor_reg(camera_instance, 0x3634,0x44);
arducam_write_sensor_reg(camera_instance, 0x3636,0x06);
arducam_write_sensor_reg(camera_instance, 0x3620,0x64);
arducam_write_sensor_reg(camera_instance, 0x3621,0xE0);
arducam_write_sensor_reg(camera_instance, 0x3600,0x37);
arducam_write_sensor_reg(camera_instance, 0x3704,0xA0);
arducam_write_sensor_reg(camera_instance, 0x3703,0x5A);
arducam_write_sensor_reg(camera_instance, 0x3715,0x78);
arducam_write_sensor_reg(camera_instance, 0x3717,0x01);
arducam_write_sensor_reg(camera_instance, 0x3731,0x02);
arducam_write_sensor_reg(camera_instance, 0x370B,0x60);
arducam_write_sensor_reg(camera_instance, 0x3705,0x1A);
arducam_write_sensor_reg(camera_instance, 0x3F05,0x02);
arducam_write_sensor_reg(camera_instance, 0x3F06,0x10);
arducam_write_sensor_reg(camera_instance, 0x3F01,0x0A);
arducam_write_sensor_reg(camera_instance, 0x3A08,0x01);
arducam_write_sensor_reg(camera_instance, 0x3A09,0x28);
arducam_write_sensor_reg(camera_instance, 0x3A0A,0x00);
arducam_write_sensor_reg(camera_instance, 0x3A0B,0xF6);
arducam_write_sensor_reg(camera_instance, 0x3A0D,0x08);
arducam_write_sensor_reg(camera_instance, 0x3A0E,0x06);
arducam_write_sensor_reg(camera_instance, 0x3A0F,0x58);
arducam_write_sensor_reg(camera_instance, 0x3A10,0x50);
arducam_write_sensor_reg(camera_instance, 0x3A1B,0x58);
arducam_write_sensor_reg(camera_instance, 0x3A1E,0x50);
arducam_write_sensor_reg(camera_instance, 0x3A11,0x60);
arducam_write_sensor_reg(camera_instance, 0x3A1F,0x28);
arducam_write_sensor_reg(camera_instance, 0x4001,0x02);
arducam_write_sensor_reg(camera_instance, 0x4004,0x04);
arducam_write_sensor_reg(camera_instance, 0x4000,0x09);
arducam_write_sensor_reg(camera_instance, 0x4837,0x16);
arducam_write_sensor_reg(camera_instance, 0x4800,0x24);
arducam_write_sensor_reg(camera_instance, 0x3503,0x03);
arducam_write_sensor_reg(camera_instance, 0x3820,0x00);
arducam_write_sensor_reg(camera_instance, 0x3821,0x02);
//arducam_write_sensor_reg(camera_instance, 0x380E,0x7F);
//arducam_write_sensor_reg(camera_instance, 0x380F,0xFF);
arducam_write_sensor_reg(camera_instance, 0x380E,0x0A);
arducam_write_sensor_reg(camera_instance, 0x380F,0xA0);
arducam_write_sensor_reg(camera_instance, 0x350A,0x02);
arducam_write_sensor_reg(camera_instance, 0x350B,0x00);
arducam_write_sensor_reg(camera_instance, 0x3500,0x07);
arducam_write_sensor_reg(camera_instance, 0x3501,0xFF);
arducam_write_sensor_reg(camera_instance, 0x3502,0xF0);
arducam_write_sensor_reg(camera_instance, 0x3212,0xA0);
arducam_write_sensor_reg(camera_instance, 0x0100,0x01);
unsigned int counter = 0;
time_t seconds;
for (counter = 0; counter < 25; counter++){
seconds = time(NULL);
sprintf(file_name, “%ld.raw”, seconds);
LOG(“Capture image %s…”, file_name);
save_image(camera_instance, file_name, width, height);
LOG(“Close camera…”);
res = arducam_close_camera(camera_instance);
if (res) {
LOG(“close camera status = %d”, res);
return 0;
