Just use the example downloaded in your previous zip package.
I successfully ran the demos.
I noticed few problems,
- The camera is not able to run at the specified FPS at the particular resolution.
when I modified
width = 1280
height = 720
framerate = 60
The console output:
fps: 16
fps: 23
fps: 25
fps: 12
fps: 29
fps: 28
fps: 15
fps: 27
fps: 24
fps: 21
fps: 25
fps: 23
fps: 27
fps: 24
fps: 19
fps: 27
when it is supposed to run at 60FPS.
- The camera color is good, but the images are visibly low in quality, with defects appearing whenever the camera is moved. Is this a known problem, is there any solution to it? I have not noticed the same issue when using the camera on PiCamera previously.
We have completely dropped the previous stuff, so there will not be any updates to the code, and there will be no maintenance.
If you really want to develop on this, we can provide the complete source code (not recommended).
