Libcamera works but picamera2 installation fails on Raspberry Pi with IMX519 OpenCV Python
Hi all. I’ve got an Arducam IMX519 camera and I’m trying to use it with OpenCV in Python on a Raspberry Pi. I followed the website steps to install libcamera, and libcamera itself is working fine — I can access the camera through libcamera. The problem is it doesn’t work from Python. I think one reason is that picamera2 isn’t installed, but every time I try to install it I get an error message. Has anyone run into this?
Here’s the error I keep getting when I try to install picamera2:
Environment details: IMX519 camera, Raspberry Pi, OpenCV, Python, libcamera working, picamera2 install failing.
Thanks for the screenshot. From what I can see, the install is failing because python3-picamera2 conflicts with Arducam’s libcamera. Since you’re running the IMX519 with Arducam’s libcamera build, the stock python3-picamera2 package clashes with it, so the installer errors out instead of completing.
To get past it, you need two steps:
  1. Remove python3-picamera2:
sudo apt-get remove --purge python3-picamera2
  1. Reinstall according to the tutorial below:
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/PiCamera2-User-Guide/
If that still doesn’t work, reflash the system and update it using the Arducam documentation.
Thanks, that fixed the install issue. After purging python3-picamera2 and reinstalling following the tutorial, the camera now works fine in Python and OpenCV. The only thing is I get warnings every time I run the code. Here’s what shows up:
Is this normal, or should I change some settings?
Glad the camera is working now. About the warnings — those are a known status on Arducam’s side. We’ve tested it and they don’t affect use. No further action is needed; the warnings won’t affect the camera’s functionality.
