Libcamera-still --list-cameras returns "No cameras available" on RPi 4B with Arducam 64MP kit
Hi, I’m stuck getting my cameras to show up at all. I’ve got the 64MP Autofocus Quad-Camera Kit with 4x Arducam cameras and the 4x in / 1x out RPi HAT. Running it on a RPi 4B 8GB, fresh install of the latest 64bit Raspberry Pi OS. When I run libcamera-still --list-cameras I just get “No cameras available!” every time. I read somewhere on the forums that standalone use of these cams isn’t possible, but I’m getting the same error whether I plug a camera straight into the Pi or attach the HAT and connect the camera through it. Followed the build/install steps in the Arducam 64MP Pi camera manual (pages 4+) exactly. Any idea what I’m missing?
Hi, thanks for the details. That error usually points at either the libcamera stack not being built/installed correctly, or a hardware connection problem. Before we assume hardware, can you send me a few things so we can rule out the software side?
  1. dpkg -l | grep libcamera
  2. ls /dev/video*
  3. Run a bug report so we can see the full state:
    camera-bug-report -t 5 -o bug.txt -c "libcamera-still -t 1000 -o test.jpg"
That last one generates a bug.txt on the Pi that captures a lot of useful info for us. Paste the first two outputs here and let me know once you have the bug report.
OK, here’s the package list:
$ dpkg -l | grep libcamera
  ii  libcamera-apps                       0.0.7                        arm64        libcamera-apps
  ii  libcamera-dev                        0.0.7                        arm64        libcamera
Both showing 0.0.7 arm64. I ran the bug report command too and got a bug.txt generated. Just to re-confirm what I tried: I went through the manual build-and-install instructions again from the PDF, and I tested the camera two ways — connected directly to the Pi, and with the HAT attached and the camera connected to the HAT. Same “No cameras available!” both times.
Thanks, that helps. The libcamera apps you’ve got installed look correct (0.0.7 arm64 is what we’d expect for that setup), and assuming you used the config file from the manual, that side checks out too.
Since the software and config both look right but no camera is being detected at all, my suspicion is there may be something wrong with the physical connection between the camera/HAT and the Raspberry Pi. Can you do the following?
  1. Re-seat all the ribbon cables, making sure the orientation of the cable is correct and the connectors are fully latched.
  2. Take a few clear photos of how everything is connected (both the camera-to-HAT and the HAT-to-Pi) and send them over.
  3. Run ls /dev/video* on the Pi and tell me if /dev/video0 shows up.
I re-seated everything and checked the ribbon cable orientation. Ran ls /dev/video* and it comes back with nothing at all — no /dev/video0, just an error about no matching files. So the Pi isn’t seeing any video device whatsoever. I’ll take the connection photos and upload them here shortly.
That’s a key detail — if there’s no /dev/video0 node at all, then the OS isn’t detecting any camera hardware, which lines up with the connection theory. Double-check that the ribbon cable is fully seated and that the contacts are facing the right way on each end, and confirm the camera module itself is the one connected to the Pi’s camera port (not a display port). Once you post the photos I can take a closer look at the cabling. If it still doesn’t enumerate after that, we’ll get you the bug report reviewed to rule out anything else on the software side. I’ve also sent you the firmware/config package via private message in case your installed files don’t quite match the version the manual expects — check your messages and try applying that if you haven’t already.
Uploaded the photos — one shows the camera plugged straight into the Pi and the other shows the full HAT setup with all four cams. Let me know if anything looks off with the cable routing or the connectors. After re-seating again I still get no /dev/video0.
Thanks for the photos. From what I can see the connectors look latched and the ribbon orientation looks correct, so at this point the most likely culprit remains the physical link between the camera/HAT and the Pi — either a damaged ribbon, a bad contact, or the camera port itself. Since the libcamera apps are confirmed correct and the config file is fine, and there’s still no video device node, I’d like to narrow it down further:
  • Try a different ribbon cable if you have one.
  • Confirm you’re plugging into the camera connector (CAM0/CAM1) and not the display port.
  • Re-run ls /dev/video* right after boot and share exactly what it returns.
Summary so far: software (libcamera 0.0.7) and config are both correct, but libcamera-still --list-cameras reports no cameras and no /dev/video0 node exists. That points squarely at the hardware connection rather than the drivers, so the next step is confirming that link is good. Once you report back on the cable swap and the device node, we can take it from there.
