https://www.amazon.com/gp/product/B09STL7S88/ref=ppx_yo_dt_b_asin_title_o00_s00 -
Model number of the product(s).
Arducam 16MP Autofocus Raspberry Pi Camera Module with ABS Case, IMX519 -
Raspberry Pi 4B, Raspberry Pi OS Bullseye Lite with XFCE for desktop -
Playing with code found on ArduCAM/Arducam-Pivariety-V4L2-Driver github repo, in the focus folder, as well as libcamera-vid commands called from subshells in python. -
Problems you were having.
I am usinglibcamera-still --list-cameras
in a POST (power on self test) to ensure that on startup we can always know whether the cameras are still being detected or not through the software. The issue is - this command is unreliable, it mostly works fine and returns “no cameras” or it lists the camera I have plugged in. But sometimes it just hangs indefinitely and only outputs:
Available cameras
I should add, this makes no sense because I know for a fact that the camera is there and working. I can start and stop it successfully using for example:
pi@raspberrypi4b-2:~/ $ DISPLAY=:0 libcamera-vid -t 0 --segment 1 --codec mjpeg -o /run/shm/test%06d.jpg --width 640 --height 480
WARNING: consider inline headers with 'pause'/split/segment/circular
Made X/EGL preview window
[1:07:46.588548508] [46033] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3729-5f595cca
[1:07:46.591558761] [46039] ERROR V4L2 v4l2_device.cpp:349 'imx519 10-001a': Unable to set controls: Device or resource busy
[1:07:46.592515370] [46039] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'imx519'
[1:07:46.592572981] [46039] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[1:07:46.611757275] [46039] WARN RPI raspberrypi.cpp:1274 Mismatch between Unicam and CamHelper for embedded data usage!
[1:07:46.612365255] [46039] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[1:07:46.612554643] [46039] INFO RPI raspberrypi.cpp:1398 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media3 and ISP device /dev/media0
Which shows me the camera stream window just fine, despite the many errors in the output (the last line seems to be most pertinent that it registers /dev/media3
and /dev/media0
- The dmesg log from your hardware.
pi@raspberrypi4b-2:~/ $ dmesg | grep -E 'vc4|bcm|imx'
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:9E:DC:9F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 console=tty3 root=PARTUUID=a4f6aa6f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo consoleblank=0 loglevel=3 quiet plymouth.enable=0 plymouth.ignore-serial-consoles plymouth.enable=0 splash
[ 0.088886] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.171938] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 1.222754] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.251139] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.413181] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.413645] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.414831] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.414850] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 4.610194] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.062200] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.069821] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.152315] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.178832] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.197057] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.206193] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.206783] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.207292] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.207720] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.207759] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.207782] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.207800] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.207817] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.215570] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.216237] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.216776] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.217196] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.217236] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.217258] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.217277] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.217293] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.217518] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.241961] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.242025] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.263812] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.263872] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.276755] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.276827] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.286479] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.286568] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.294736] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 5.294815] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.722617] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 6.725460] bcmgenet fd580000.ethernet eth0: Link is Down
[ 7.228329] imx519: loading out-of-tree module taints kernel.
[ 7.254722] imx519 10-001a: Device found is imx519
[ 7.257283] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 7.311769] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.324123] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.324216] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 7.324567] vc4_hdmi fef00700.hdmi: 'dmas' DT property is missing or empty, no HDMI audio
[ 7.324616] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.332283] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.332365] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 7.334826] vc4_hdmi fef05700.hdmi: 'dmas' DT property is missing or empty, no HDMI audio
[ 7.334870] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.335500] vc4-drm gpu: bound fe700000.dsi (ops vc4_dsi_ops [vc4])
[ 7.335903] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.336081] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.336205] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.336326] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.336421] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.336552] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.349761] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.871876] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 395.848468] imx519 10-001a: Failed to write reg 0x561f. error = -5
[ 395.848477] imx519 10-001a: imx519_start_streaming failed to set common settings
[ 706.851425] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 713.027467] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 717.415451] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 728.135509] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 730.179482] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
Troubleshooting attempts you’ve made
I’m going to work around this by wrapping my unit test function with a timeout decorator. For the sake of digging deeper and finding the actual underlying issue - I don’t know where to start (so I am posting here now for help). -
Reassurance that this is not normal behavior? Anyone else getting this issue? If yes, what causes it? Is it not perhaps the responsibility of the tool itself to implement a timeout if this a known problem for more than just one user? Maybe something from my dmesg logs will help indicate why this is happening? What value for the timeout is reasonable, 1s, 5s?
