Libcamera-still fails for 64MP Autofocus Camera (failed to allocate capture buffers)
    Ordered from arducam website
    [email protected]
    Raspberry Pi 3 Model B Rev 1.2
    https://www.arducam.com/downloads/arducam_64mp_pi_camera_manual.pdf
  5. Problems you were having?
[email protected]:~ $ libcamera-still -t 1000 -o test.jpg
Preview window unavailable
[0:07:03.920844419] [1523]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:07:03.931162610] [1525]  WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:07:03.931343393] [1525]  WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:07:03.932629234] [1525] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:07:03.974721952] [1525]  WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:07:03.976878424] [1525] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:07:03.977553116] [1525]  INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media0
[0:07:03.979093647] [1523]  INFO Camera camera.cpp:1029 configuring streams: (0) 4624x3472-YUV420
[0:07:03.980241883] [1525]  INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[0:07:04.028585006] [1525] ERROR V4L2 v4l2_videodevice.cpp:1218 /dev/video14[16:cap]: Not enough buffers provided by V4L2VideoDevice
ERROR: *** failed to allocate capture buffers ***
[email protected]:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.32-v8+ ([email protected]) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022
[    0.000000] random: fast init done
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000037400000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000] percpu: Embedded 28 pages/cpu s77144 r8192 d29352 u114688
[    0.000000] pcpu-alloc: s77144 r8192 d29352 u114688 alloc=28*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 238896
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3151d8b6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 862276K/970752K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 42940K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 37889 entries in 149 pages
[    0.000000] ftrace: allocated 149 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: bcm2836_arm_irqchip_handle_irq
[    0.000000] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000303] Console: colour dummy device 80x25
[    0.000373] printk: console [tty1] enabled
[    0.000442] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.000478] pid_max: default: 32768 minimum: 301
[    0.000669] LSM: Security Framework initializing
[    0.000867] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.000910] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.002591] cgroup: Disabling memory control group subsystem
[    0.006109] rcu: Hierarchical SRCU implementation.
[    0.007520] EFI services will not be available.
[    0.008371] smp: Bringing up secondary CPUs ...
[    0.009871] Detected VIPT I-cache on CPU1
[    0.009963] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.011717] Detected VIPT I-cache on CPU2
[    0.011779] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.013495] Detected VIPT I-cache on CPU3
[    0.013553] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.013760] smp: Brought up 1 node, 4 CPUs
[    0.013788] SMP: Total of 4 processors activated.
[    0.013806] CPU features: detected: 32-bit EL0 Support
[    0.013820] CPU features: detected: 32-bit EL1 Support
[    0.013837] CPU features: detected: CRC32 instructions
[    0.053199] CPU: All CPU(s) started at EL2
[    0.053312] alternatives: patching kernel code
[    0.055300] devtmpfs: initialized
[    0.077262] Enabled cp15_barrier support
[    0.077314] Enabled setend support
[    0.077595] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.077639] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.081709] pinctrl core: initialized pinctrl subsystem
[    0.082881] DMI not present or invalid.
[    0.083540] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.094449] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.094956] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.096441] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.096604] audit: initializing netlink subsys (disabled)
[    0.097030] audit: type=2000 audit(0.096:1): state=initialized audit_enabled=0 res=1
[    0.097885] thermal_sys: Registered thermal governor 'step_wise'
[    0.098207] cpuidle: using governor menu
[    0.098828] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.099110] ASID allocator initialised with 65536 entries
[    0.099359] Serial: AMBA PL011 UART driver
[    0.112076] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.136647] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:20:54, variant start
[    0.140672] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[    0.199420] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.204895] vgaarb: loaded
[    0.205596] SCSI subsystem initialized
[    0.205926] usbcore: registered new interface driver usbfs
[    0.206008] usbcore: registered new interface driver hub
[    0.206108] usbcore: registered new device driver usb
[    0.206603] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.207224] pps_core: LinuxPPS API ver. 1 registered
[    0.207243] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.207280] PTP clock support registered
[    0.209740] clocksource: Switched to clocksource arch_sys_counter
[    0.346567] VFS: Disk quotas dquot_6.6.0
[    0.346705] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.346955] FS-Cache: Loaded
[    0.347266] CacheFiles: Loaded
[    0.362690] NET: Registered PF_INET protocol family
[    0.363002] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.364923] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.364981] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.365110] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.365315] TCP: Hash tables configured (established 8192 bind 8192)
[    0.365604] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.365670] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.366093] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.367324] RPC: Registered named UNIX socket transport module.
[    0.367344] RPC: Registered udp transport module.
[    0.367360] RPC: Registered tcp transport module.
[    0.367375] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.367401] PCI: CLS 0 bytes, default 64
[    0.370255] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.370583] kvm [1]: IPA Size Limit: 40 bits
[    0.372307] kvm [1]: Hyp mode initialized successfully
[    1.869614] Initialise system trusted keyrings
[    1.870193] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    1.880841] zbud: loaded
[    1.883625] FS-Cache: Netfs 'nfs' registered for caching
3
[   17.838458] Bluetooth: HCI UART protocol H4 registered
[   17.838657] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   17.839107] Bluetooth: HCI UART protocol Broadcom registered
[   18.074423] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[   18.435362] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.435409] Bluetooth: BNEP filters: protocol multicast
[   18.435498] Bluetooth: BNEP socket layer initialized
[   18.483125] NET: Registered PF_ALG protocol family
[   20.704134] Bluetooth: RFCOMM TTY layer initialized
[   20.704250] Bluetooth: RFCOMM socket layer initialized
[   20.704339] Bluetooth: RFCOMM ver 1.11
[   33.757789] cam-dummy-reg: disabling
[   36.676793] cma: cma_alloc: linux,cma: alloc failed, req-size: 5941 pages, ret: -12
[   36.676892] ------------[ cut here ]------------
[   36.676903] WARNING: CPU: 0 PID: 1128 at mm/page_alloc.c:5380 __alloc_pages+0x2d0/0x330
[   36.676945] Modules linked in: rfcomm cmac algif_hash aes_arm64 algif_skcipher af_alg bnep hci_uart btbcm bluetooth ecdh_generic ecc hid_logitech_hidpp arducam_64mp(O) dw9807_vcm(O) 8021q garp stp llc hid_logitech_dj joydev brcmfmac brcmutil cfg80211 rfkill raspberrypi_hwmon i2c_mux_pinctrl i2c_mux bcm2835_unicam v4l2_dv_timings v4l2_fwnode v4l2_async bcm2835_codec(C) bcm2835_isp(C) bcm2835_v4l2(C) v4l2_mem2mem bcm2835_mmal_vchiq(C) snd_bcm2835(C) i2c_bcm2835 videobuf2_vmalloc snd_pcm videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 snd_timer videobuf2_common snd vc_sm_cma(C) videodev mc uio_pdrv_genirq uio i2c_dev drm drm_panel_orientation_quirks backlight fuse ip_tables x_tables ipv6
[   36.677393] CPU: 0 PID: 1128 Comm: libcamera-still Tainted: G         C O      5.15.32-v8+ #1538
[   36.677413] Hardware name: Raspberry Pi 3 Model B Rev 1.2 (DT)
[   36.677424] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   36.677441] pc : __alloc_pages+0x2d0/0x330
[   36.677459] lr : __dma_direct_alloc_pages+0x168/0x1b0
[   36.677479] sp : ffffffc00a67b880
[   36.677487] x29: ffffffc00a67b880 x28: ffffff8011ed5060 x27: ffffffc00a67bb58
[   36.677516] x26: 0000000000000001 x25: ffffffc008115144 x24: 0000000000000000
[   36.677544] x23: 0000000001735000 x22: 0000000000000cc1 x21: ffffffc008e8a9c8
[   36.677572] x20: ffffff8002a1b410 x19: ffffffc008e8a9c8 x18: 0000000000000001
[   36.677601] x17: 72202c7365676170 x16: 2031343935203a65 x15: 7a69732d71657220
[   36.677629] x14: 2c64656c69616620 x13: 32312d203a746572 x12: ffffffc0093a6670
[   36.677657] x11: 0000000000000003 x10: ffffffc00938e630 x9 : ffffffc008115788
[   36.677685] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : ffffff803717a908
[   36.677712] x5 : 0000000000000001 x4 : 000000000000003f x3 : 0000000000000000
[   36.677738] x2 : 0000000000000000 x1 : 000000000000000d x0 : 0000000000000cc1
[   36.677765] Call trace:
[   36.677775]  __alloc_pages+0x2d0/0x330
[   36.677794]  __dma_direct_alloc_pages+0x168/0x1b0
[   36.677812]  dma_direct_alloc+0x7c/0x330
[   36.677828]  dma_alloc_attrs+0xac/0xc0
[   36.677844]  vb2_dc_alloc+0x70/0x130 [videobuf2_dma_contig]
[   36.677871]  __vb2_queue_alloc+0x220/0x488 [videobuf2_common]
[   36.677928]  vb2_core_reqbufs+0x288/0x480 [videobuf2_common]
[   36.677975]  vb2_ioctl_reqbufs+0x8c/0xc8 [videobuf2_v4l2]
[   36.678017]  v4l_reqbufs+0x54/0x68 [videodev]
[   36.678173]  __video_do_ioctl+0x188/0x410 [videodev]
[   36.678301]  video_usercopy+0x310/0x7d0 [videodev]
[   36.678431]  video_ioctl2+0x20/0x38 [videodev]
[   36.678561]  v4l2_ioctl+0x48/0x68 [videodev]
    I tried change /boot/config.txt, no luck. This is my /boot/config.txt right now
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-fkms-v3d,cma-512
dtoverlay=arducam_64mp
gpu_mem=128
  1. What help do you need?
    The camera seems not working on my raspberry pi, please fix the bug.
So one thing to be aware of - the preview window can only launch if operating terminal directly on the Raspberry Desktop itself (or if operating via VNC). It will not launch via a terminal on a different machine. Not sure if that is relevant to your case - but I had a hard time figuring that out
Also, the image will not be shown after saving - it merely writes it to the user’s home directory ~/
Not sure if that helps at all
I connected raspberry pi to TV with hdmi cable, and saw the same errors.
Hi! Just replying to keep track of this thread. I’m having the exact same issue. Any solution?
In case anyone had the same issue Try this (works on my 4GB RAM PI) - leave the config.txt file as normal (dont specify any cma allocation there), add cma=712M to the end of the first line in the /boot/cmdline.txt file. Reboot, Try now.
