I recently purchased the Pivariety AR0234 2.3MP Color Global Shutter Camera Module and I cannot seem to get it to work. It is directly connected to my Raspberry Pi 4B 4GB. I have attempted both 32bit Lite and 64bit Lite and get stuck at the same point.
I followed https://forum.arducam.com/t/arducam-ar0234-error/2566 to install the proper drivers. However I always get no cameras available
Preview window unavailable
[0:00:32.882786332] [734] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3896-6019b245
[0:00:32.903336461] [735] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam-pivariety'
[0:00:32.903389128] [735] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:00:32.926793683] [735] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
Open i2c bus error: No such file or directory
[0:00:32.927494054] [735] WARN RPiController controller.cpp:71 Failed to open tuning file ''
[0:00:32.927552887] [735] ERROR IPARPI raspberrypi.cpp:249 Failed to load tuning data file
[0:00:32.927600665] [735] ERROR RPI raspberrypi.cpp:1275 Failed to load a suitable IPA library
[0:00:32.927822702] [735] ERROR RPI raspberrypi.cpp:1190 Failed to register camera arducam-pivariety 10-000c: -22
However I get
[ 7.588059] arducam-pivariety 10-000c: firmware version: 0x10003
[ 8.249542] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
and
crw-rw---- 1 root video 81, 14 Oct 11 23:21 /dev/video0
crw-rw---- 1 root video 81, 2 Oct 11 23:21 /dev/video10
crw-rw---- 1 root video 81, 5 Oct 11 23:21 /dev/video11
crw-rw---- 1 root video 81, 7 Oct 11 23:21 /dev/video12
crw-rw---- 1 root video 81, 1 Oct 11 23:21 /dev/video13
crw-rw---- 1 root video 81, 3 Oct 11 23:21 /dev/video14
crw-rw---- 1 root video 81, 4 Oct 11 23:21 /dev/video15
crw-rw---- 1 root video 81, 6 Oct 11 23:21 /dev/video16
crw-rw---- 1 root video 81, 8 Oct 11 23:21 /dev/video18
crw-rw---- 1 root video 81, 0 Oct 11 23:21 /dev/video19
crw-rw---- 1 root video 81, 10 Oct 11 23:21 /dev/video20
crw-rw---- 1 root video 81, 11 Oct 11 23:21 /dev/video21
crw-rw---- 1 root video 81, 12 Oct 11 23:21 /dev/video22
crw-rw---- 1 root video 81, 13 Oct 11 23:21 /dev/video23
crw-rw---- 1 root video 81, 9 Oct 11 23:21 /dev/video31
and
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
[8]: 'RGB3' (24-bit RGB 8-8-8)
[9]: 'BGR3' (24-bit BGR 8-8-8)
[10]: 'RGB4' (32-bit A/XRGB 8-8-8-8)
[11]: 'BA81' (8-bit Bayer BGBG/GRGR)
[12]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[13]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[14]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[15]: 'pBAA' (10-bit Bayer BGBG/GRGR Packed)
[16]: 'BG10' (10-bit Bayer BGBG/GRGR)
[17]: 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
[18]: 'GB10' (10-bit Bayer GBGB/RGRG)
[19]: 'pgAA' (10-bit Bayer GRGR/BGBG Packed)
[20]: 'BA10' (10-bit Bayer GRGR/BGBG)
[21]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
[22]: 'RG10' (10-bit Bayer RGRG/GBGB)
[23]: 'pBCC' (12-bit Bayer BGBG/GRGR Packed)
[24]: 'BG12' (12-bit Bayer BGBG/GRGR)
[25]: 'pGCC' (12-bit Bayer GBGB/RGRG Packed)
[26]: 'GB12' (12-bit Bayer GBGB/RGRG)
[27]: 'pgCC' (12-bit Bayer GRGR/BGBG Packed)
[28]: 'BA12' (12-bit Bayer GRGR/BGBG)
[29]: 'pRCC' (12-bit Bayer RGRG/GBGB Packed)
[30]: 'RG12' (12-bit Bayer RGRG/GBGB)
[31]: 'pBEE' (14-bit Bayer BGBG/GRGR Packed)
[32]: 'BG14' (14-bit Bayer BGBG/GRGR)
[33]: 'pGEE' (14-bit Bayer GBGB/RGRG Packed)
[34]: 'GB14' (14-bit Bayer GBGB/RGRG)
[35]: 'pgEE' (14-bit Bayer GRGR/BGBG Packed)
[36]: 'GR14' (14-bit Bayer GRGR/BGBG)
[37]: 'pREE' (14-bit Bayer RGRG/GBGB Packed)
[38]: 'RG14' (14-bit Bayer RGRG/GBGB)
[39]: 'GREY' (8-bit Greyscale)
[40]: 'Y10P' (10-bit Greyscale (MIPI Packed))
[41]: 'Y10 ' (10-bit Greyscale)
[42]: 'Y12P' (12-bit Greyscale (MIPI Packed))
[43]: 'Y12 ' (12-bit Greyscale)
[44]: 'Y14P' (14-bit Greyscale (MIPI Packed))
[45]: 'Y14 ' (14-bit Greyscale)
Which makes no sense to me because the tutorial says that everything should be working. What am I missing?
