From Aducam Buy store. -
B0393 -
Raspberry Pi4 ModelB Rev.1.4 -
Arducam documentation -
I’ve installed Raspberry OS (64-bit) BullsEye from Raspberry repository with Raspberry Pi Imager.
Linux raspberrypi 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
libcambera-hello -t 0 works perfectly.
I’ve used the github RaspberryPi repository to test Motorized_Focus_Camera python demo but
in python path there are the whell only for 32 bit python version:
libcamera-1.0.1-cp39-cp39-linux_armv7l.whl
libcamera-1.0.2-cp39-cp39-linux_armv7l.whl
The libcamera python packages for 64 bits python 3.9 or code to build them in 64bits.
Note:
When I try to get info about BSK b0393 with v4l2-ctl -D -d /dev/video0 --list-formats-ext
I obtain wrong data from supported resolutions:
qem@raspberrypi:~ $ v4l2-ctl -D -d /dev/video0 --list-formats-ext
Driver Info:
Driver name : unicam
Card type : unicam
Bus info : platform:fe801000.csi
Driver version : 5.15.32
Capabilities : 0xa5a00001
Video Capture
Metadata Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x25200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : unicam
Serial :
Media version : 5.15.32
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000005 : 0: Sink
Link 0x02000008: from remote pad 0x1000002 of entity ‘imx219 10-0010’: Data, Enabled, Immutable
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
[8]: 'RGB3' (24-bit RGB 8-8-8)
[9]: 'BGR3' (24-bit BGR 8-8-8)
[10]: 'RGB4' (32-bit A/XRGB 8-8-8-8)
[11]: 'BA81' (8-bit Bayer BGBG/GRGR)
[12]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[13]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[14]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[15]: 'pBAA' (10-bit Bayer BGBG/GRGR Packed)
[16]: 'BG10' (10-bit Bayer BGBG/GRGR)
[17]: 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
[18]: 'GB10' (10-bit Bayer GBGB/RGRG)
[19]: 'pgAA' (10-bit Bayer GRGR/BGBG Packed)
[20]: 'BA10' (10-bit Bayer GRGR/BGBG)
[21]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
[22]: 'RG10' (10-bit Bayer RGRG/GBGB)
[23]: 'pBCC' (12-bit Bayer BGBG/GRGR Packed)
[24]: 'BG12' (12-bit Bayer BGBG/GRGR)
[25]: 'pGCC' (12-bit Bayer GBGB/RGRG Packed)
[26]: 'GB12' (12-bit Bayer GBGB/RGRG)
[27]: 'pgCC' (12-bit Bayer GRGR/BGBG Packed)
[28]: 'BA12' (12-bit Bayer GRGR/BGBG)
[29]: 'pRCC' (12-bit Bayer RGRG/GBGB Packed)
[30]: 'RG12' (12-bit Bayer RGRG/GBGB)
[31]: 'pBEE' (14-bit Bayer BGBG/GRGR Packed)
[32]: 'BG14' (14-bit Bayer BGBG/GRGR)
[33]: 'pGEE' (14-bit Bayer GBGB/RGRG Packed)
[34]: 'GB14' (14-bit Bayer GBGB/RGRG)
[35]: 'pgEE' (14-bit Bayer GRGR/BGBG Packed)
[36]: 'GR14' (14-bit Bayer GRGR/BGBG)
[37]: 'pREE' (14-bit Bayer RGRG/GBGB Packed)
[38]: 'RG14' (14-bit Bayer RGRG/GBGB)
[39]: 'GREY' (8-bit Greyscale)
[40]: 'Y10P' (10-bit Greyscale (MIPI Packed))
[41]: 'Y10 ' (10-bit Greyscale)
[42]: 'Y12P' (12-bit Greyscale (MIPI Packed))
[43]: 'Y12 ' (12-bit Greyscale)
[44]: 'Y14P' (14-bit Greyscale (MIPI Packed))
[45]: 'Y14 ' (14-bit Greyscale)
It is normal ?
Seem v4l2 can’t get info about camera.
