UCTRONICS -
Arducam 18MP USB Camera Evaluation Kit - CMOS AR1820HS 1/2.3−inch Color Camera with USB3 Camera Shield and MIPI Adapter Board -
Nvidia Jetson -
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield,
SDK and Examples for Nvidia Jetson - Arducam,
/docs/camera-breakout-board/18mp-ar1820hs/ (Arducam site, forum won’t let me add a third link) -
When trying to run an arducam node or the arducam demo, obtained erroropen fail,rtn_val = 65281
SUMMARY
CLEAR PARAMETERS
* /arducam0/
PARAMETERS
* /arducam0/arducam_trigger_ros_node/camera_serial:
* /arducam0/arducam_trigger_ros_node/config_file: /home/lux/Code/pa...
* /arducam0/arducam_trigger_ros_node/frame_id: arducam0
* /arducam0/arducam_trigger_ros_node/horizontal_flip: False
* /arducam0/arducam_trigger_ros_node/vertical_flip: False
* /rosdistro: melodic
* /rosversion: 1.14.13
NODES
/arducam0/
arducam_trigger_ros_node (arducam_usb2_ros/arducam_trigger_ros_node.py)
auto-starting new master
process[master]: started with pid [7979]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 5312f6ee-0f52-11ed-9d96-00044be6f253
process[rosout-1]: started with pid [7992]
started core service [/rosout]
process[arducam0/arducam_trigger_ros_node-2]: started with pid [8001]
color mode 2
[arducam0/arducam_trigger_ros_node-2] process has finished cleanly
log file: /home/lux/.ros/log/5312f6ee-0f52-11ed-9d96-00044be6f253/arducam0-arducam_trigger_ros_node-2*.log
After adjusting the arducam.rules file to correspond to IDs found in lsusb, now obtain error : Error capture image, rtn_val = 65318
NODES
/cam0/
arducam_ros_node (arducam_usb2_ros/arducam_ros_node.py)
process[master]: started with pid [8738]
setting /run_id to 457c4a5a-0f55-11ed-895d-00044be6f253
process[rosout-1]: started with pid [8751]
process[cam0/arducam_ros_node-2]: started with pid [8760]
color mode 2
USB VERSION: 3
Serial: AU3S-2220-0003
Capture began, rtn_val = 0
Will add in reply -
Replacing the ros/arducam ArducamSDK.so with the one from the NVidia Jetson example
Installing Arducam SDK through pip
Editing udev rules to correspond to product ID found in lsusb command
Running camera on windows to confirm it works (it works)
Switching out cables and cameras (tried with 3 different cameras and cables)
Checking camera detection with v4l2-util (camera is not detected)
Installing the latest libusb library
Running Arducam Jetson python demo to confirm issue isn’t with ros (same error obtained) -
Troubleshooting tips or instructions on how to get the camera to be detected.
