Are there any status updates on drivers for Jetpack 6, Orin NX/nano?
Which camera module do you need?
This is the item name on the order “Arducam OV9281 1MP Global Shutter NoIR Camera Module for NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX”
But it’s a Jetvariety module so whichever drivers that uses. I tried to install the deb file from the releases but since the package versions for l4t-core have changed it wouldn’t install. I tried to extract it and manually work through the installation process but I haven’t been able to spend too much time on it.
You can try to download the drive in the link below to your Jetson Orin Nano:
Run the command to install it:
sudo dpkg -i arducam-nvidia-l4t-kernel-t234-nano-5.15.136-tegra-36.3.0-20240521161750_arm64.deb
Awesome! I’ll give it a try. Hopefully I can finally start making real progress with the hyperspectral imaging system I’m building.
Are there any docs on how the external shutter trigger can be used? I need to trigger the frame capture with a gpio pulse in order to synchronize it with the pwm variable band pass filter I’m making.
May the link below help you:
https://docs.arducam.com/Nvidia-Jetson-Camera/Global-Shutter-Camera/external-trigger/
Have the Jetson Linux 36.4 drivers been made yet?
Have the drivers for L4T 36.4.7 been made yet?
I was running the ones for 36.4.4 and they were working fine… Then I accidently did the kernel update and nothing works anymore. I was thinking of flashing back to 36.4.4, but I don’t even know where I got that driver.
Is there a place where we can have the list of all the available drivers, as they come out?
