Issue with Arducam 12MP 4-Camera Kit: Error When Using Only Two Cameras
I recently set up the Arducam 12MP Quadrascopic Camera Bundle Kit (B0397) on my Raspberry Pi 4B. The setup works perfectly when all four cameras/sensors are connected. However, I am encountering an issue when I attempt to use only two cameras.
When only two cameras are connected, the system fails to initialize, and I receive the following error message:
pi@raspberrypi:~ $ libcamera-hello
[2:49:40.823502143] [2044]  INFO Camera camera_manager.cpp:325 libcamera v0.3.2+99-1230f78d
[2:49:40.863893622] [2047]  WARN RPiSdn sdn.cpp:40 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[2:49:40.866136859] [2047]  INFO RPI vc4.cpp:447 Registered camera /base/soc/i2c0mux/i2c@1/imx477@1a to Unicam device /dev/media2 and ISP device /dev/media1
[2:49:40.866217525] [2047]  INFO RPI pipeline_base.cpp:1120 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Preview window unavailable
Mode selection for 2028:1520:12:P
    SRGGB10_CSI2P,1332x990/0 - Score: 3456.22
    SRGGB12_CSI2P,2028x1080/0 - Score: 1083.84
    SRGGB12_CSI2P,2028x1520/0 - Score: 0
    SRGGB12_CSI2P,4056x3040/0 - Score: 887
[2:49:40.867630030] [2044]  INFO Camera camera.cpp:1197 configuring streams: (0) 2028x1520-YUV420 (1) 2028x1520-SBGGR12_CSI2P
[2:49:40.867970842] [2047]  INFO RPI vc4.cpp:622 Sensor: /base/soc/i2c0mux/i2c@1/imx477@1a - Selected sensor format: 2028x1520-SBGGR12_1X12 - Selected unicam format: 2028x1520-pBCC
[2:49:42.406051306] [2047]  WARN V4L2 v4l2_videodevice.cpp:2127 /dev/video0[13:cap]: Dequeue timer of 1000000.00us has expired!
[2:49:42.406124250] [2047] ERROR RPI pipeline_base.cpp:1366 Camera frontend has timed out!
[2:49:42.406137620] [2047] ERROR RPI pipeline_base.cpp:1367 Please check that your camera sensor connector is attached securely.
[2:49:42.406151527] [2047] ERROR RPI pipeline_base.cpp:1368 Alternatively, try another cable and/or sensor.
For context:
The camera kit works flawlessly with all four cameras connected.
I have verified the physical connections and confirmed the cameras are securely attached.
The Raspberry Pi is running Debian Bookworm, and I have libcamera installed.
The relevant configurations in /boot/firmware/config.txt are adjusted based on the Arducam documentation.
I have another kit set up on another raspberry few months ago and it works fine with only two sensors connected.
Has anyone experienced a similar issue or have insights into why the kit only works with all four cameras connected? Could this be related to software configuration or the device tree overlay?
Thank you in advance for your help!
