Hi Iam recently purchased ArduCam B0323 Pivariety 16MP IMX298 Color Camera Module for RPi,while install pre-compiled driver with guidance ArduCam website ,i have faced an issue
Hardware Revision: d03114
Kernel Version: 5.10.63-v7l+
(sorry for minimal data new user allowed to give only two links)please give support to solve this issue
I have tried your advice by Downloading libcamera-dev.deb and installed it . By checking
libcamera-still -t 5000 -o test.jpg ,it give libcamera-still: error while loading shared libraries: libcamera.so.0: cannot open shared object file: No such file or directory
And please use the following commands when installing: sudo apt install ./xxx.deb
If you are using the latest bullseye you also need to uninstall libcamera0: sudo apt remove libcamera0
Dear Sir, Thank you for your kind advice , now I am able to read camera image with libcamera . at last I have an small doubt ,is that pivariety camera can access by Opencv Videocapture method
Unfortunately, VideoCapture using opencv can only read RAW data (you can view the format through v4l2-ctl --list-formats-ext).
You can find information about V4l2loopback in the document. It is a compromise method. It uses libcamera to get data and send it to the video node.
Sir ,I have tried your advice for v4l2loopback to acess camera via opencv . But I have an doudt, v4l2loopback command is has to be run at background to access camera image using opencv in respective program. Incase I exit that command,I could not able to access camera via opencv . is there any solution for this issue
In fact, this is not a problem. Memory data can be easily converted to cv::Mat. Are you looking for C++ code or Python? We have a simple Python wrapper that can be used.
