Pihut - Model number of the product(s)?
B0270 - What hardware/platform were you working on?
Pi4B Bullseye latest - Instructions you have followed. (link/manual/etc.)
Arducam manual - Problems you were having?
It has been working ok for a short while but now the filter seems to get stuck halfway and blocks the lens so nothing can be seen through the lens. - The dmesg log from your hardware?
There is no software problem message, this is hardware issue with the module - Troubleshooting attempts you’ve made?
trying to engage and disenage the filter using a cover over the photo resistor to see if it helps to make it work again. - What help do you need?
Troubleshooting steps to fix it, or is it best to return it?
Thanks
ok it’s working again for now after I restarted the Pi, not sure what happened but will keep an eye on it…
